Help me with mtexts and text string
I want to iterate through the mtexts of a given drawing and export them to Excel.suppose that there is an mtext in the drawing named mtextobj in which "sample" is written in the first line and "note" is written in the 2nd.this would be read as "sample note". i use TextString property:
Dim mtextobj As AcadMText
MsgBox mtextobj .TextString
and autocad returns "sample\Pnote". this is appropriate for me.
the problem is when text formatting of this mtext is changed.for example if i double click on the mtext and in the Text Formatting box change the color to red,autocad returns
{\C1;sample\Pnote}
or if i change the font to verdana it gives
{\fVerdana|b0|i0|c0|p34;sample\fVerdana|b0|i0|c178|p34;\P\fVerdana|b0|i0|c0|p34;note}
How can i access to the real content inside the mtext? and get rid of this string which is merged with text formatting data?
any help is highly appreciated... Message was edited by: arman88
Try this one
Option Explicit
' written by Bryco
Function UnformatMtext(S As String) As String
Dim P1 As Integer
Dim P2 As Integer, P3 As Integer
Dim intStart As Integer
Dim strCom As String
Dim strReplace As String
Debug.Print S
Select Case Left(S, 4)
Case "\A0;", "\A1;", "\A2;"
S = Mid(S, P1 + 5)
End Select
intStart = 1
Do
P1 = InStr(S, "%%")
If P1 = 0 Then
Exit Do
Else
Select Case Mid(S, P1 + 2, 1)
Case "P"
S = Replace(S, "%%P", "+or-")
Case "D"
S = Replace(S, "%%D", " deg")
End Select
Loop
Do
P1 = InStr(intStart, S, "\", vbTextCompare)
If P1 = 0 Then Exit Do
strCom = Mid(S, P1, 2)
Select Case strCom
Case "\p"
P2 = InStr(1, S, ";")
S = Mid(S, P2 + 1)
Case "\A", "\C", "\f", "\F", "\H", "\Q", "\T", "\W"
P2 = InStr(P1 + 2, S, ";", vbTextCompare)
P3 = InStr(P1 + 2, S, strCom, vbTextCompare)
If P3 = 0 Then
S = Left(S, P1 - 1) & Mid(S, P2 + 1)
Do While P3 > 0
P2 = InStr(P3, S, ";", vbTextCompare)
S = Left(S, P3 - 1) & Mid(S, P2 + 1)
'Debug.Print s, strCom
P3 = InStr(1, S, strCom, vbTextCompare)
Loop
's = Left(s, P3 - 1) & mid(s, P3 + 1)
'Case "\L", "\O"
'Dim strLittle As String
'strLittle = LCase(strCom)
'P2 = InStr(P1 + 2, S, strLittle, vbTextCompare)
'S = Left(S, P1 - 1) & Mid(S, P1 + 2, P2 - (P1 + 2)) & Mid(S, P2 + 2)
'//============== fixed by fla_2
'// example {\fArial|b1|i0|c0|p34;\LGENERAL NOTES :}
Case "\L", "\O"
If P2 = 0 Then
S = Left(S, P1 - 1) & Mid(S, P1 + 2)
Else
Case "\S"
P3 = InStr(P1 + 2, S, "/", vbTextCompare)
If P3 = 0 Or P3 > P2 Then
P3 = InStr(P1 + 2, S, "#", vbTextCompare)
P3 = InStr(P1 + 2, S, "^", vbTextCompare)
S = Left(S, P1 - 1) & Mid(S, P1 + 2, P3 - (P1 + 2)) _
& "/" & Mid(S, P3 + 1, (P2) - (P3 + 1)) & Mid(S, P2 + 1)
Case "\U"
strLittle = Mid(S, P1 + 3, 4)
Debug.Print strLittle
Select Case strLittle
Case "2248"
strReplace = "ALMOST EQUAL"
Case "2220"
strReplace = "ANGLE"
Case "2104"
strReplace = "CENTER LINE"
Case "0394"
strReplace = "DELTA"
Case "0278"
strReplace = "ELECTRIC PHASE"
Case "E101"
strReplace = "FLOW LINE"
Case "2261"
strReplace = "IDENTITY"
Case "E200"
strReplace = "INITIAL LENGTH"
Case "E102"
strReplace = "MONUMENT LINE"
Case "2260"
strReplace = "NOT EQUAL"
Case "2126"
strReplace = "OHM"
Case "03A9"
strReplace = "OMEGA"
Case "214A"
strReplace = "PROPERTY LINE"
Case "2082"
strReplace = "SUBSCRIPT2"
Case "00B2"
strReplace = "SQUARED"
Case "00B3"
strReplace = "CUBED"
End Select
S = Replace(S, "\U+" & strLittle, strReplace)
Case "\~"
S = Replace(S, "\~", " ")
Case "\\"
intStart = P1 + 2
S = Replace(S, "\\", "\")
GoTo Selectagain
Case "\P"
intStart = P1 + 1
GoTo Selectagain
Case Else
Exit Do
End Select
Selectagain:
Loop
Do
P1 = InStr(1, S, "\P", vbTextCompare)
If P1 = 0 Then
Exit Do
Else
S = Left(S, P1 - 1) & vbCrLf & Mid(S, P1 + 2)
Loop
For intStart = 0 To 1
If intStart = 0 Then
strCom = "}"
Else
strCom = "{"
P2 = InStr(1, S, strCom)
Do While P2 > 0
S = Left(S, P2 - 1) & Mid(S, P2 + 1)
Loop
Next intStart
UnformatMtext = S
End Function
Sub Testmt()
Dim Mt As AcadMText, V As Variant
ThisDrawing.Utility.GetEntity Mt, V, "Pick an Mtext:"
Debug.Print Mt.textString
Mt.textString = UnformatMtext(Mt.textString)
MsgBox Mt.textString
End Sub
WOWWWWW . Thanksssss a lot! That works pretty well. I used that function and this code:
Sub Testmt()
Dim Mt As AcadMText
Dim obj As AcadObject
For Each obj In ThisDrawing.ModelSpace
If obj.ObjectName = "AcDbMText" Then
Set Mt = obj
Debug.Print Mt.TextString
Mt.TextString = UnformatMtext(Mt.TextString)
Next
End Sub
This way all mtexts in the drawing corrected in the way i want.It dosn't change boundaries, size , insertion point,attachmentpoint and layer of mtexts. right? because I want those properties to be left original.I checked and it seems ok.
Thanks again Fatty! and Thanks Bryco!
Yeah, thanks Bryco
~'J'~
i found lisp code for that too.
try .lsp and .dcl in the attachments
