Get points from circle/arc circumference
andriamparany.ralambomahay
I would like to get the points which on the circumference of circle or arc.
The same points that autocad shows when we select circle or arc.
Is there a command or another API to do that or I have to compute it ?
Thanks for any tips.
Ed__Jobe
You might want to explain better what you are trying to do. VBA can set osnaps and running osnaps, but it doesn't have much to calculate points. You have to do the math yourself. NET has a lot more functions for getting points on curves.
Ed
How to post your code.
I would like to extract the center, and 4 points on each circle on a file. This data will be the entry point for another non autocad dependent app.
Ed__Jobe
VBA can give you the Center point and then you can just use math to calculate the quadrants by adding or subtracting the radius from x or y.
Ed
I have found a solution here
https://forums.autodesk.com/t5/vba/create-point-on-a-3d-circle/m-p/7706298#M101152
I have missed the usage of TranslatedCoordinates.
