Get civil objects function civil 3d 2015
jcoon
Message 1 of 21
jcoon
All,
Because I just installed civil 3d 2015 with the VBA 7.1 enabler installed I thought I’d use a few routines I had made several years ago in VBA to speed up the drawing creation when I found out the get civil objects function fails at 10.4. I read in the reference library was for civil 3d 2015 was 10.4.
Is there a newer a newer way to retrieve the civil objects ?
I connected the Autodesk Civil Engineering 10.4 UI Land Object library
And the Autodesk Civil Engineering 10.4 Land Object library as weel as the Autocad 2015 type library
I thought this would be all I needed to use a trusted routine I had used for years in many versions of civil 3D.
Thanks you,
John
This is the old function I’ve used for years:
Function GetBaseCivilObjects() As Boolean
   Dim oApp As AcadApplication
   Set oApp = ThisDrawing.Application
   ' NOTE - Always specify the version number.
   Const sAppName = "AeccXUiLand.AeccApplication.10.4"
   Set g_oCivilApp = oApp.GetInterfaceObject(sAppName)
   If (g_oCivilApp Is Nothing) Then
       MsgBox "Error creating " & sAppName & ", exit."
       GetBaseCivilObjects = False
       Exit Function
   Set g_oDocument = g_oCivilApp.ActiveDocument
   Set g_oAeccDatabase = g_oDocument.Database
   GetBaseCivilObjects = True
End Function
Replies (20)
Message 2 of 21
Alfred.NESWADBA
"AeccXUiLand.AeccApplication.10.4" is the correct ProgID parameter for GetInterfaceObject.
As long as you use VBA it's the current method/API, if you want to change to C# or VB.NET you have a bit more options.
Just to remember: there is a special forum for Civil 3D customization >>>there<<<.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 21
jcoon
Alfred,
Even with the function I attached and with "AeccXUiLand.AeccApplication.10.4" library attached I still seem to get and error
on programs that I 've run for years without issue.
These were VBA routines I didn't convert to dot net. I thought with 2015 and the new VBA 7.1 enablier I might be able to use some old rouutine to help finish a project.
I guess I keep looking. It's not a big issue as I have not used these routines in some time, as I said I thought I just need to change the function library numbers and i would be go to go.
Thanks for the help and confirming I had the correct library.
John
Message 4 of 21
Alfred.NESWADBA
if you want to continue...
Which error message/number do you get (at what code-line)?
- alfred -
Alfred NESWADBA
Message 5 of 21
jcoon
Alfred,
I spent a good bit of time over the weekend looking for anything in civil 3D Dev. guide on VBA  settings to connect to the civil object.
attached are the library connections I was using and the function is the same as posted.
what about something that reads the surfaces in a dwg.  As I said, It would be nice to be able to use some older VBA routines that I didn't convert to dot net. Maybe I should find the time to convert them or see if it's easier to connect with lisp for older routines.
'get surface names
If (GetBaseCivilObjects() = False) Then
        Exit Sub
Dim surfaceName As String
Dim oAcadObject As AcadObject
Dim osurf As AeccSurface
For Each oAcadObject In ThisDrawing.ModelSpace
If (TypeOf oAcadObject Is AeccSurface) Then
Set osurf = oAcadObject
surfaceName = osurf.name
Next
'print to command line
       Exit Function
End Function
Message 6 of 21
Alfred.NESWADBA
I'm not sure to see a question in your post. ... or if your code fails then where does it fail and what error message you get.
You can use the older routines, just change the ProgID to the current version of Civil 3D and all should run well.
- alfred -
Alfred NESWADBA
Message 7 of 21
Dylandavid
NEED A DIFFERENT LIBRARY? When I load a sample .DVB it tries to reference: Autodesk Civil Engineering 8.0 [land, survey, ui land, ui survey]
I beleive that's the problem but I'm not sure. I think they've depricated help for this so I don't know how to find out
My vanilla AutoCAD 2015 macros still work swimmingly
See image below, notice path in vba ui caption
Message 8 of 21
Alfred.NESWADBA
Yep, not all samples are updated to fit the current Civil 3D release, so it might be necessary to update the references.
- alfred -
Alfred NESWADBA
Message 9 of 21
jcoon
Dylanddavid,
That sounds like what I was getting as well. All the Autocad only dvb worked fine. The civil 3d objects even with the updated link to library AeccXUiLand.AeccApplication.10.4 I could not get to work. I tought it was something I was doing wrong so I even went into the C3D tutoral samples provided with the software and all the Civil ones have been removed. I guess the VBA only works with vanilla autocad.
John
Message 10 of 21
jcoon
Alfred
Please see that I have the new library selected from vba 7
I think I have everything set correctly.
John
Message 11 of 21
Alfred.NESWADBA
let's exchange DVB files, because screenshots can't be tried 😉
I have attached a DVB that is working for me on Civil 3D 2015, SP2, German on Windows 8.1 Prof. 64bit.
- alfred -
Alfred NESWADBA
Message 12 of 21
norman.yuan
Just to back up Alfred's case, with my newly installed Civil 3D 2015 SP2 with Win 7 64-bit Enterprise, the folloing simple code works (that is, the VBA code has no issue creating AeccApplication object (with reference set to "Autodesk,Civil Engineering 10.4 UI Land Object Library"):
Option Explicit
Public Sub CivilTest()
    Dim cadApp As AcadApplication
    Dim civilApp As AeccApplication
    Set cadApp = ThisDrawing.Application
    Set civilApp = cadApp.GetInterfaceObject("AeccXUiLand.AeccApplication.10.4")
    MsgBox civilApp.ActiveDocument.FullName
End Sub
Norman Yuan
Drive CAD With Code
Message 13 of 21
jcoon
Norman.yuan,
Wouldn't you know it,  I didn't bring my lap[top in today becuase I had a project going out today. maybe I can get it during lunch otherwise I'll have to check tonight.
Thanks guys for looking into this. you guys are the best!
John
Message 14 of 21
jcoon
Alfred, Norman.yuan
Well it looks like it might be my machine. It's only a month old..... I have 2015 civil 3d installed with sp1 & 2 installed and I get the same error as before.
I tried both vba routines you posted. no joy
I guess this means that I'm going to select the old vba appys that I liked and convert them to dot net.
my machine is
win 8.1 with AMD a10-5745m apu
error was -2147221005(80041f3)   ..... problem in loading application
if anyone knows where or what to lok for
Thank you for all your help with this. I'll contine to keep looking for a solution. The good side is that the AUTOCAD ONLY apps still work.
Thank you
John
Message 15 of 21
Alfred.NESWADBA
you might try:
run a repair installation of your Civil 3D (antivirus off, internet off, as admin)
start Excel, within that VBA and just try to activate the reference to the C3D lib's, that might do some registration if missing.
Good luck, - alfred -
Alfred NESWADBA
Message 16 of 21
jcoon
Alfred,
Sounds like a plan for lunch. Thanks for the idea
John
Message 17 of 21
Dylandavid
MY USER ERROR
Your dvb worked for me. I didn't have the .application set up. Thanks for the example file
Message 18 of 21
Hello, my name is David and I have recently installed Autocad Civil 3D 2015 and VBA Enabler 7.1 for it to run old VBA Routines that are currently working in 2013 version with the VBA enabler 6.3 for 2013. Everything is installed and when I run the routine it goes through the prompts but once get to certain part where makes custom layer gives me the below error then takes me to my .dvb file. Checked under the references in the VBA editor and 2015 content library is selected. Is there something else that needs to be done, wondering what the problem could be. Thank you for any help you can give.
Message 19 of 21
jcoon
UZA1717,
I followed everything from Alfred posts and still could not get mine to work. I used the samples Alfred and Norman.yuan posted and they just didn't work on my machine. I ended up rewriting them for dot net.
Sorry I couldn't help
John
Message 20 of 21
Alfred.NESWADBA
We don't see your code, what's the code-lines that bring up that message?
- alfred -
Alfred NESWADBA
