For Each - Next with a 2 dimensional array
I have an array dimensioned (1 to 30, 1 to 3), and
I need to step through
the first dimension and look at one of the values in
the second dimension.
For example, in one situation, I would look at (1-30,1)
while in another
situation I would need to look at (1-30,2). Specifically, I
have a list of
30 items, with in effect a synonym (and sometimes two
synonyms), and at
different times I need to look up one based on another. The
data might look
something like this:
array (1,1) = "768": array (1,2) =
"1/64" & Chr(34) & "=1'": array (1,3) =
acVp1_64in_1ft
the last
being an AutoCAD constant that may or may not apply, as I am using
some
scales that AutoCAD has no constant for.
At times I need to step through
looking for "768" to get "1/64" & Chr(34)
"=1'"
:  or acVp1_64in_1ft, at other
times I am searching for "1/64" & Chr(34)
"=1'"
to get "768" .
At this point I am
doing this with an array, and would like to use For
Each - Next rather than a
counter. Then again, maybe there is a better data
structure for what I am
doing?
I had thought about using a collection, but I suspect I will
eventually want
to populate the data structure from a file or database, and
as far as I can
tell, a collection requires hard coding to define. Again I
may be wrong.
Any help is GREATLY
appreciated!
Gordon
PS Sorry for the HTML post, but this was one
occation where that bold really comes in
handy!
I've never tried it with multidimensional arrays but you can use a For
Each loop to iterate an array:
Dim var As Variant
For Each var In myArray
Next
http://www.acadx.com
"Gordon Price" wrote in
message news:A91456760727365FB4A9A97E5CA60974@in.WebX.maYIadrTaRb...
I'm not sure if the for each works on 2 dim arrays.
But another way around this is to create one new class "ArrayElement" which has
three properties, "768", "1/64" and "acVp1_....." Then create an array of
objects of the class type. Takes up a bit more memory though.
Cheers,
 Coen
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
"Gordon Price" <gordon.price(nospam)@albedoconsulting.com> wrote in
message
href="news:A91456760727365FB4A9A97E5CA60974@in.WebX.maYIadrTaRb">news:A91456760727365FB4A9A97E5CA...
and I need to step through
values in the second dimension.
at (1-30,1) while in another
Specifically, I have a list of
sometimes two synonyms), and at
on another. The data might look
array (1,1) =
"768": array (1,2) = "1/64" & Chr(34) & "=1'": array (1,3)
acVp1_64in_1ft
the last being an AutoCAD constant that may or may not
some scales that AutoCAD has no constant for.
At
times I need to step through looking for "768" to get
"1/64" & Chr(34) &
"=1'"
:  or
acVp1_64in_1ft, at other times I am searching for
"1/64" & Chr(34)
& "=1'"
to get
"768" .
At this point I am doing this with an array,
Each - Next rather than a counter. Then again,
structure for what I am doing?
I had
thought about using a collection, but I suspect I will eventually want
to
populate the data structure from a file or database, and as far as I
can
tell, a collection requires hard coding to define. Again I may be
wrong.
Any help is GREATLY appreciated!
Gordon
handy!
arrays. But another way around this is to create one new class "ArrayElement"
which has three properties, "768", "1/64" and "acVp1_....." Then create an
array of objects of the class type. Takes up a bit more memory though.
That was the route I ended up taking. You
do loose the For Each - Next option tho'. Oh well, as long as it
works!
Gordon
If you use a collection object to store the object
you can do the for each....
Something like this:
dim c as new collection
c.additem <obj>
message
href="news:24A6BBB30962CE2FB8D10C485CB7770A@in.WebX.maYIadrTaRb">news:24A6BBB30962CE2FB8D10C485CB77...
"ArrayElement" which has three properties, "768", "1/64" and "acVp1_....."
Then create an array of objects of the class type. Takes up a bit more
memory though.
works!
size=2>Gordon
Instead of creating a multidimensional array, create
an array of arrays. Declare your array like that:
'Declare and initialize my array
Dim mat(1 To 30) As Variant
Dim tmp(1 To 3) As
String
Dim i as Integer
For i = 1 to 30
    mat(i) = tmp
Next
Then, access your elements like that:
Dim var As Variant
For Each var In
mat
    MsgBox var(3)
Next
Hope this helps.
Alain
message
array (1,1) =
acVp1_64in_1ft
At
"1/64" & Chr(34) &
"=1'"
:  or
"1/64" & Chr(34)
& "=1'"
to get
"768" .
I had
to
can
wrong.
Gordon
handy!
