Excel VBA - Get selected points coordinates
cool.stuff
Message 1 of 12
cool.stuff
Hi!!!!
I'm trying to get the points coordinates from AutoCAD to Excel, using a Excel macro.
I have no experience in Excel API to acess AutoCAD data..
Could someone help me please? It would save me hours of work!! 🙂
Many many thanks!!! 🙂
Replies (11)
Message 2 of 12
grobnik
You should modify the path for open a new template.
See picture below, you have to create a command button in excel, assign the macro below, and try.
Sub Macro_Cad()
    Dim acadApp As Object
'Check if AutoCAD is open.
   ' On Error Resume Next
    Set acadApp = GetObject(, "AutoCAD.Application")
    On Error GoTo 0
    'If AutoCAD is not opened create a new instance and make it visible.
   If acadApp Is Nothing Then
        Set acadApp = CreateObject("AutoCAD.Application")
        acadApp.Visible = True
    'Check if there is an active drawing.
    Set acadDoc = acadApp.ActiveDocument
    'No active drawing found. Create a new one.
    If acadDoc Is Nothing Then
        Set acadDoc = acadApp.Documents.Add("C:\Users\IO\AppData\Local\Autodesk\AutoCAD Mechanical 2021\R24.0\enu\Template\acad.dwt")
MyScreenPoint = acadDoc.Utility.GetPoint(, "Select Insertion Point: ")
Range("E3").Value = MyScreenPoint(0)
Range("F3").Value = MyScreenPoint(1)
Range("G3").Value = MyScreenPoint(2)
End Sub
Message 3 of 12
grobnik
If you want to avoid to insert path and become macro more generic, you can modify the macro as showed below.
strTemplatePath = ThisDrawing.Application.Preferences.Files.TemplateDwgPath
Set acadDoc = acadApp.Documents.Add(strTemplatePath & "\acad.dwt")
Message 4 of 12
cool.stuff
Many many thanks!! 🙂
Works like a charm! 🙂
Could you please make it work for the current point selection?
I have 30 or 40 points to extract each time I have to run distance verifications, it would be awesome! 🙂
It is possible please?
Many many thanks again! 🙂
Message 5 of 12
grobnik
Hi  thank you for your message.
I'll try, should be able to trap the selection event on autocad.
For above reason should be better transfer the macro on Autocad side instead inside Excel.
I'll try
Message 6 of 12
cool.stuff
Thank you for helping me!!!! 🙂
You'll try o do it in ACAD VBA?
I should be able to convert it to Excel VBA right? 🙂
Message 7 of 12
grobnik
No it's no possibile to convert, VBA base it's more or less the same, but
in order to trap the event you should be in Autocad development area.
However I'll try.
Message 8 of 12
grobnik
Hi @cool.stuff
here the code revised, I created a loop and Excel row increasing until you press "ESC" on Autocad for exit from point selection.
Sub Macro_Cad()
   ' On Error GoTo 0
    'On Error Resume Next
A = 3
Here:
If Err <> 0 Then
        Err.Clear
        End
Else
    Range("E" & A).Value = MyScreenPoint(0)
    Range("F" & A).Value = MyScreenPoint(1)
    Range("G" & A).Value = MyScreenPoint(2)
    A = A + 1
GoTo Here
End Sub
Let me know Bye
Message 9 of 12
cool.stuff
Your code works perfectly!!! 🙂
Many many thanks!!!
However, in my spreadsheet it does not work (it stops after the first points). This is due to some code I've written before... If I paste your code in a new spreadsheet it works perfectly!! 🙂
Maybe this is due to the Err.. Do you have any idea please?
Again, many many thanks!!! 🙂
Message 10 of 12
grobnik
Hi, could you pass me your spreadsheet?? Now I have some issue with
Autocad, but I'll try.
Did you assigned macro correctly? Share a screenshot of error got
Bye
Message 11 of 12
cool.stuff
Hi!!!! Many thanks for your answer!! 🙂
I would kindly give you the spreadsheet but it is from the company I work for..
I got no error 🙂
It just does not ask for more points. After the first iteration, it stops.
I dont know the remaining code contained in the spreadsheet..
As I said before, when I copy your macro to a new spreadsheet it works perfectly 🙂
Message 12 of 12
grobnik
Ok,
You got no error due to there is an instruction "on error resume next" that allows you to skip the error but in the mean time you cannot have a debugging.
Try to use F8 function key and try to
run the procedure step by step pressing F8 on each instruction and try to check where is the error.
With out any other element I cannot help you more.
