02:52 PM
Hi All,
i have been using this function in Inventor 2010. we now upgraded to 2016 and this function does not work anymore.
I also have got Active x and Excel library references loaded.
Seems "dbconnection.Open dbconnectionstring is not working now. Is this related to inventor migrating to EXCEL API?
i am lost and any help is appreciated.
Jiten
Public Function ReadDataFromWorkbook(SourceFile, SourceRange As String) As Variant 'Public Function Since it is also used in Frm_iproperties
' requires a reference to the Microsoft ActiveX Data Objects library
' requires a reference to the Microsoft Excel 14.0 Object library
' if SourceRange is a range reference, this function can only return data from the first worksheet in SourceFile
' if SourceRange is a defined name reference, this function can return data from any worksheet in SourceFile
' SourceRange must include the range headers
' examples:
' varRecordSetData = ReadDataFromWorkbook("C:\FolderName\SourceWbName.xls", "A1:A21")
' varRecordSetData = ReadDataFromWorkbook("C:\FolderName\SourceWbName.xls", "A1:B21")
' varRecordSetData = ReadDataFromWorkbook("C:\FolderName\SourceWbName.xls", "DefinedRangeName")
Dim dbConnectionString As String, dbConnection As ADODB.Connection, rs As ADODB.Recordset
dbConnectionString = "DRIVER={Microsoft Excel Driver (*.xls)};ReadOnly=False;DBQ=" & SourceFile
'dbConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0;" & "Data Source=" & SourceFile & ";Extended Properties=Excel 8.0;HDR=Yes"
Set dbConnection = New ADODB.Connection
MsgBox dbConnectionString
On Error GoTo InvalidInput
'dbConnection.ConnectionString = dbConnectionString
dbConnection.Open dbConnectionString ' open the database connection ' 32bit office clashes with 64 bit inventor here
Set rs = dbConnection.Execute("[" & SourceRange & "]")
On Error GoTo 0
ReadDataFromWorkbook = rs.GetRows ' returns a two dim array with all records in rs
rs.Close
dbConnection.Close ' close the database connection
Set rs = Nothing
Set dbConnection = Nothing
On Error GoTo 0
Exit Function
InvalidInput:
MsgBox "The source file or source range is invalid!" & SourceFile & err, vbExclamation, "Get data from closed workbook"
Set rs = Nothing
End Function
