Edit Nested Block Attributes in VBA
Good Day to everyone,
I'm running into a bit of an issue here.
My purpose is to write a VBA code that will edit a particular attribute of all the nested blocks within the selected parent block. I have so far achieved a code that can change the particular attribute of a non nested block my desired value.
I figure with this code, all I would need to do is add "For each Entity (child blocks) within the Entity ( parent that i have chosen)". But this is seemingly wrong, maybe because i need to look for entities within the Block Reference and not the block itself,I'm really not too sure.
I've attached below the code that works for a single non nested block, would anyone point me in the right direction to make this work by selecting a parent block, and having all ASSYNO attributes changed to the parent blocks name?
Public Sub TestGetAttributes()
Dim varPick As Variant
Dim objEnt As AcadEntity
Dim objBRef As AcadBlockReference
Dim varAttribs As Variant
Dim strAttribs As String
Dim intI As Integer
On Error Resume Next
With ThisDrawing.Utility
'' get an entity from user
GetEntity objEnt, varPick, vbCr & "Pick a block with attributes: If Err Then Exit Sub"
'Set Ref
Set objBRef = objEnt
'' exit if not a block
If objBRef Is Nothing Then
MsgBox ("That wasn't a block.")
'' exit if it has no attributes
If Not objBRef.HasAttributes Then
MsgBox ("That block doesn't have attributes.")
'' get the attributerefs
varAttribs = objBRef.GetAttributes
'' Change ASSYNO to the blocks name
strAttribs = objBRef.Name
For intI = LBound(varAttribs) To UBound(varAttribs)
If varAttribs(intI).TagString = "ASSYNO" Then
varAttribs(intI).TextString = strAttribs
Next
MsgBox strAttribs
End With
End Sub
norman.yuan
Firstly, I'd say having a block reference with attributes added in a block definition (thus, the nested block) isn't a very good practice in most cases. But this is the fact you have not control and have to deal with it using your code...
So, let's assume you have a block definition named "MyNestBlock", which has a block reference with attributes (AcadAttributeReference) in it. Following code demonstrates how to edit the attributes of nested block (AcadBlockreference) in a block definition (of course you know all the block reference to this block definition would show the same changes of nested block's attributes):
Dim blkDef As AcadBlock
Set blkDef=ThisDrawing.Blocks("MyNestBlock") '' Assume the block definition does exist in ThisDrawing
Dim ent As AcadEntity
Dim blkRef As AcadBlockReference
Dim att As AcadAttributeReference
Dim atts As Variant
Dim i As Integer
For Each ent in blkDef
    If TypeOf ent Is AcadBlockReference Then
        Set blkRef = ent
        If blkRef.HasAttributes Then
            atts=blkRef.GetAttributes()
            For i=0 To UBound(atts)
                Set att = atts(i)
                Select UCase(att.TagString)
                    Case "AAAA"
                       att.TextString="xxxxxxxxxx"
                   Case "BBBBB"
                      att.TextString="yyyyyyyyyy"
               End Select
            Next
        Exit For '' Assume you know there is only one nested block reference in the definition
Next
'' After updating the block definition, you may want to Regen the drawing
ThisDrawing.Regen acAllViewports
HTH
Norman Yuan
Drive CAD With Code
