Hi guys, today AutoCAD is not working right... When I double-click text/mtext, leaders or dimensions, the selection set is lost and the command continues, asking for a selection set. Basically I double click and I get "*cancel* *cancel* _TEXTEDIT" after doubleclicking text and have to re-select the text object I just double clicked. PICKFIRST = 1, MTEXTED = "Internal", DBLCLKEDIT = ON, and the CUI is still the default file... Everything was working fine on last Friday, today it doesn't want to work. Double click tables and attributed blocks works just fine... Any suggestions?
