Create a silhouette
Create a silhouette
Create a silhouette
Hi all,
Probably best to view the attached .jpg first.
I’m looking to get from item ‘A’ (see .jpg) to item ‘B’? I’m starting w/ 3D solids, running a flatten routine on it and removing duplicate lines. I want to take it a step further and programmatically create a silhouette of the tool for a plant layout. But I’m having a bit of trouble w/ the logic.
This example is a simple one and only takes a few minutes to do, but for more complex items, cleaning it up or re-tracing can be very time consuming.
Has anyone got any advice or maybe some sample code to get me started?
VBA or Lisp......
Thank you Message was edited by: KeystoneKopp
Try AutoCAD's "boundary" command against your 3D solids.
See soldraw, solview and profile AutoCAD commands
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
wrote in message news:5154115@discussion.autodesk.com...
Hi all,
I'm looking to get from item 'A' (see .jpg) to item 'B'? I'm starting w/ 3D
the tool for a plant layout But I'm having a bit of trouble w/ the logic.
more co
VBA or Lisp......
Thank you
Thank you guys for the quick replies.....and I probably should've been clearer. I'm not always dealing with 3D solids. Sometimes it's a car panel (like an underbody) and it's just a webbing of lines, splines, arcs, circles, etc..
Other times it's a Robot blob. Kind of a cloud of lines representing the travel of a robot. And for clean system layouts everything must reside on Z zero..
We're that far right now....we just want to clean up the unnecessary details. Message was edited by: KeystoneKopp
Put a circle around the whole thing and then use
the boundary command picking a point between
your object and the circle. You will get an outline
of your object as a pline or region.
gl - Paul
Hi all,
more co
VBA or Lisp......
Thank you
Thank you,
I had been playing around w/ 'Boundary' after the first response, but I kept selecting stuff as my boundary set....that does 2/3 of what I need to do. Great w/ solids and w/ simple lines. Doesn't work w/ 3dfaces (what my car panels end up as by the time that we translate them from CATIA)....any other ideas
For anybody who might be looking for the answer to making the silhouette w/ 3dfaces you can't explode them using the .explode command. So use the Express tools Flatten.lsp first, then then run the boundary routine.
