VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Counting Blocks with similar names
4 REPLIES 4
141 Views, 4 Replies
This is more of a database question but here goes: I think it is pretty
basic.
I am using VBA/ADO to count the number of blocks in a drawing. I am trying
to count (or sum) the number of blocks whose names begin with "S_" (e.g.
S_1, S_2, S_3). E.g., if there are three of each of the blocks, the sum
would be nine.
Can anyone help?
Thanks.....Sean
4 REPLIES 4
Hi Sean,
When you say "database question", do you mean "the drawing database" or
an external db? In the drawing, you can iterate the modelspace
collection and check for instances of "acadblockreference" with a name
that starts with "S". Since your checking instances, it will return a
valid count including duplicates.
-Josh
> basic.
> would be nine.
> Can anyone help?
> Thanks.....Sean
Use a filtered selection set:
Dim ss As AcadSelectionSet
Dim fType, fData
Set ss = CreateSelectionSet
BuildFilter 0, "INSERT", 2, "S_*"
ss.Select acSelectionSetAll, , , fType, fData
Debug.Print "Total blocks = " & ss.Count
See the VB section of my site for the CreateSelectionSet and BuildFilter
functions.
http://www.acadx.com
Good judgement comes from experience.
Experience comes from bad judgement.
"Sean" wrote in message
news:B3CA88363A616A28E91A1DCE05D58CD5@in.WebX.maYIadrTaRb...
> basic.
> would be nine.
> Can anyone help?
> Thanks.....Sean
thanks to you both. cheers
"Frank Oquendo" wrote in message
news:32ADB364C389B1C5AD456762BFA5CBB4@in.WebX.maYIadrTaRb...
> Dim fType, fData
> functions.
> > basic.
trying
> > would be nine.
> > Can anyone help?
> > Thanks.....Sean
Typo alert. Replace the call to BuildFilter:
BuildFilter fType, fData, 0, "INSERT", 2, "S_*"
Forma Design Contest
