VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Change text of leader note
2 REPLIES 2
hieut1392
137 Views, 2 Replies
I want to change the existing content of a leader note with the content I specify by clicking. Can anyone help me?
2 REPLIES 2
norman.yuan
in reply to: hieut1392
To clarify, are you talking a "Leader" entity, or "MLeader"? Assume it is MLeader, you can simply reach AcadMLeader.TextString property:
Option Explicit
Public Sub GetMLeaderContent()
    Dim pt As Variant
    Dim ent As AcadEntity
    Dim mleader As AcadMLeader
    Dim leaderText As String
    On Error Resume Next
    ThisDrawing.Utility.GetEntity ent, pt, vbCr & "Select a MLeader object:"
    If ent Is Nothing Then Exit Sub
    If TypeOf ent Is AcadMLeader Then
        Set mleader = ent
        leaderText = mleader.TextString
        MsgBox "MLeader's content: " & leaderText
    Else
        MsgBox "No an MLeader object!"
End Sub
Norman Yuan
Drive CAD With Code
hieut1392
Thanks for respone
AutoCAD Inside the Factory
