Autocad _VBA
Autocad _VBA
Autocad _VBA
Hi
I try to update the AutoCAD attribute by excel VBA uses the below code.
Dim acadApp As AcadApplication
'On Error Resume Next
Set acadApp = GetObject(, AcAppClID)
If acadApp Is Nothing Then
Set acadApp = CreateObject(AcAppClID)
acadApp.Visible = False
Dim Document As AcadDocument
i get the error message "run-time error 429 activex component can't create object"
Pls help
grobnik
Hi @Anonymous
I'm suggesting to check your Excel Code as below example, I guess your code Set acadApp = GetObject(, AcAppClID) it's not correct, if you do not defined the Variable AcAppClID before, in any case should be better apply the canonic standard code.
Sub Opendwg()
    Dim acadApp As Object
    Dim acadDoc As Object
'Check if AutoCAD is open.
    Set acadApp = GetObject(, "AutoCAD.Application")
    On Error GoTo 0
    'If AutoCAD is not opened create a new instance and make it visible.
        Set acadApp = CreateObject("AutoCAD.Application")
        acadApp.Visible = True
    'Check if there is an active drawing.
    Set acadDoc = acadApp.ActiveDocument
    On Error GoTo 0
    'No active drawing found. Create a new one.
    If acadDoc Is Nothing Then
        Set acadDoc = acadApp.Documents.Add
End Sub
 Let us know
Hi @grobnik
Thank you for your reply. Already  Variable AcAppClID. Attached image for your reference.
I try your code also, it's also showing the error. The image is attached for reference.
Thanks.
grobnik
Hi @Anonymous ,
thank you for your message, seems very strange as error type and in any case it's quiet different from previous one you got, so it's not related to an ActiveX issue, but to "elevation" that it's not mentioned or settled inside the code.
Could be a silly question but you should develop software inside Excel, and as second issue are you able to execute my code step by step (F8) and highlight where the code hangs ?.
As third issue you can make an image of project reference inside Excel ? like picture below ?
Bye,
