VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
AutoCAD 2025 crash on exit after loading VBA
23 REPLIES 23
Message 1 of 24
capuano3d
2740 Views, 23 Replies
Only in AutoCAD 2025 (not Civil 3D 2025) I get a crash when I exit it everytime I load (and not necessarily run) any VBA routine. Other people that I'm in contact with are getting the same.
Is that an AutoCAD bug? Any thoughts?
23 REPLIES 23
Message 21 of 24
ed57gmc
in reply to: DavidTosh
@DavidTosh wrote:
Too Long, Didn't Read?
1. A completely empty VBA project loaded does not trigger the crash report dialog on exit.
2. The insertion of a UserForm into the project with absolutely no code does trigger the crash report on exit.
I read it, it's just not the same issue for me. It always crashes even if no project is loaded.
Ed
How to post your code.
Message 22 of 24
ed57gmc
@DavidTosh wrote:
report number 778392028.
Where would that be located?
Ed
Message 23 of 24
DavidTosh
in reply to: ed57gmc
That's the error report reference in the crash reporting dialog. I assume it can be referenced by Autodesk -- if they follow up on this.
BTW, I and several of my coworkers are now (this afternoon) are reporting on problems with PUBLISH when background publishing is checked triggering one crash report dialog for each document in the publish job and, even worse, no PDF output in the directed target location.
Tosh
Message 24 of 24
p_goodman
in reply to: capuano3d
The AutoCAD 2025.1.1 update fixed all VBA issues for me.
I had to uninstall and reinstall the VBA Enabler after installing the update.
Thank you Autodesk.
Happy Customer,
Peter Goodman
Waterman Group (AUS) Pty Ltd
AutoCAD Inside the Factory
