Auto-Enrty of Drawing Numbers
Message 1 of 8
I dont know if this possible, but this is what I would like to do:
When a drawing is opened (any drawing), through my computer, Mechanical
Desktop will search for either a text string or attribute and replace it
with the drawing's file name (less the .dwg).
I basically want to make a tool that will automatically fill in the drawing
number when the file is saved as its drawing number (eliminate the drawing
file name and the title block drawing number not matching)
Chris
Replies (7)
Message 2 of 8
Use the BeginSave event to create a filtered selection set containing only your
title block(s). From there, iterate the set, retreive the attributes, iterate
the attributes until you find the tag you're interested in and change the
TextString property.
http://www.acadx.com
Win a free autographed copy of
"AutoCAD 2000 VBA Programmer's Reference"
"MaJicMrLn" wrote in message
news:[email protected]...
> Chris
Message 3 of 8
Thanx for the Help (as always)
Chris
"Frank Oquendo" wrote in message
your
iterate
drawing
drawing
> > Chris
Message 4 of 8
Here's a code clip from one of the numerous tblock subs I've written. I usually
use the select case statement these days, it's less typing, but none the less, a
picture says a thousand words 🙂
If BlkRef.HasAttributes Then
AttArray = BlkRef.GetAttributes
For I = LBound(AttArray) To UBound(AttArray)
If AttArray(I).TagString = "TT2" Then
AttArray(I).TextString = DateTime.Date
ElseIf AttArray(I).TagString = "LDR_BY" Then
AttArray(I).TextString = "JDW"
ElseIf AttArray(I).TagString = "LCHKD_BY" Then
AttArray(I).TextString = "RMS"
ElseIf AttArray(I).TagString = "LDRAWN_DATE" Then
ElseIf AttArray(I).TagString = "LCHKD_DATE" Then
AttArray(I).TextString = "AUG 99"
ElseIf AttArray(I).TagString = "TT17" Then
AttArray(I).TextString = "53020799/53020800"
ElseIf AttArray(I).TagString = "TT29" Then
AttArray(I).TextString = ThisDrawing.Application.Name
ElseIf AttArray(I).TagString = "TT1" Then
AttArray(I).TextString = "---------"
ElseIf AttArray(I).TagString = "TT26" Then
AttArray(I).TextString = "1999"
ElseIf AttArray(I).TagString = "TT3" Then
AttArray(I).TextString = "FULL"
ElseIf AttArray(I).TagString = "TT34" Then
AttArray(I).TextString = "--------"
ElseIf AttArray(I).TagString = "TT9" Then
AttArray(I).TextString = "130"
ElseIf AttArray(I).TagString = "TT10" Then
AttArray(I).TextString = "TBD"
ElseIf AttArray(I).TagString = "TT7" Then
ElseIf AttArray(I).TagString = "TT6" Then
ElseIf AttArray(I).TagString = "TT12" Then
ThisDrawing.Application.ActiveDocument.FullName
ElseIf AttArray(I).TagString = "TT4" Then
Mid$(ThisDrawing.Application.ActiveDocument.Name, 5, 2)
> Chris
> your
> iterate
> drawing
> drawing
> > > Chris
Message 5 of 8
How do you identify that the BlkRef refers to the Title Block???
Chris
"Minkwitz Design" wrote in message
usually
less, a
> > Chris
only
> > your
> > iterate
the
Mechanical
replace it
> > drawing
> > drawing
> > > > Chris
Message 6 of 8
Sorry, with the following declarations :
Dim Obj As Object
Dim BlkRef As AcadBlockReference
You would use:
For Each Obj In 'the name of your filtered sset (which is faster in big
drawings) _
or ThisDrawing.ModelSpace if you don't have a sset of the blocks
If TypeOf Obj Is AcadBlockReference Then 'you only need this if you
didn't filter for blocks
Set BlkRef = Obj
'you can also check the name of the block here if you didn't
filter for it by using:
'if blkref.name = "yattayatta"
If you've already built a filtered selection set, which contains only blocks
with your title block, you can shorten all this to just:
for each blkref in sset
But you can not use for each blkref in thisdrawing.modelspace, because the
first time the loops sees a entity that is not a block reference, you will get
a type mismatch error. Are you doing this to a large number of drawings? Do you
have MS Office on your system? If so, I may have something pretty much tailored
to what you want, I would just need to clear out customer stuff and post it. If
you want, just post the block name of your title block and I'll post back after
lunch. Then you'll just have to patch it up with your tag names and the info
you want filled in.
-Josh 🙂
> Chris
> usually
> less, a
> > > Chris
> only
> > > your
> > > iterate
> the
> Mechanical
> replace it
> > > drawing
> > > drawing
> > > > > Chris
Message 7 of 8
Beware!! I created a mess using the SELECT method in BeginSave. Everything worked fine until autosave kicked in. Autosave also triggers the BeginSave event, and somehow doing a select in the BeginSave event causes an infinite loop during an autosave.
Message 8 of 8
Unless I'm missing something in your request, it
seems like you don't need code at all for this. I use Rtext for this kind of
thing, from the express tools menu (stands for reactive text).
Type RTEXT, then D for Diesel, then type this in
dialog box:
size=2>$(substr,$(getvar,dwgname),1,$(-,$(strlen,$(getvar,dwgname)),4))
this will return just the drawing name, minus the
extension.
