VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Assign view to page setup
0 REPLIES 0
Message 1 of 1
sa_jekov
69 Views, 0 Replies
Can someone Help me. I want ot create pdf based oncordinates. I get them from other part of code.But i cant make it create it the window my cordinates. This is my code
Sub ExportPDFWithCustomSettings()
' Declare variables for plot settings and coordinates
Dim plotSettings As Object
Dim minPt As Variant, maxPt As Variant
Dim plotScale As Double
Dim paperSize As String
Dim plotFilePath As String
' Coordinates for the plot window (bottom-left corner and top-right corner)
minPt = Array(0, 0) ' Bottom-left corner (0, 0)
maxPt = Array(2920, 2050) ' Top-right corner (2920, 2050)
' Get the Plot object from the current drawing
Set plotSettings = ThisDrawing.Plot
' Set the plot area to custom window (acWindow)
plotSettings.PlotArea = acWindow ' Use acWindow to define custom window for plotting
' Define the custom plot window area with the coordinates (minPt and maxPt)
ThisDrawing.Plot.SetPlotWindowArea minPt, maxPt
' Set the plot scale (1:5)
plotScale = 5 ' 1:5 scale
plotSettings.plotScale = plotScale
' Set paper size to ISO Expand A3
plotSettings.paperSize = "ISO Expand A3"
' Set plot rotation to 0 degrees (no rotation)
plotSettings.PlotRotation = 0 ' No rotation
' Set to center the plot on the paper
plotSettings.CenterPlot = True
' Set the output file path for the PDF
plotFilePath = "C:\path\to\output\yourfile.pdf" ' Change this path to your desired location
plotSettings.PlotToFile = True
plotSettings.PlotFileName = plotFilePath
' Execute the plot to file (generate PDF)
ThisDrawing.Plot.PlotToFile plotFilePath
' Display a message when done
MsgBox "Plotting complete. PDF saved to: " & plotFilePath
End Sub
0 REPLIES 0
AutoCAD Inside the Factory
