Zooming
Zooming
Message 1 of 16
Zooming
I want to save the current view in the active viewport, prompt for some
picks (allowing the user to zoom/pan at will), then reset the active
viewport to the saved view. When I coded this, restoring the view forced a
regen. I don't want that.
Is there a way to save the current zoom scale and reset it when I am
finished? I know there is a zoom scale but I'm not sure which Acad variable
holds this current value. Any help would be appreciated.
Keith
Replies (15)
Message 2 of 16
Check the Viewport object's CustomScale property.
John Goodfellow
irtf'nm
use 'microtouch' in address to email
"Keith" wrote in message
news:FD809212B3CE44847E95D38BE7291DB2@in.WebX.maYIadrTaRb...
a
variable
> Keith
Message 3 of 16
When trying:
Dim CurrentZoomScale As Variant
CurrentZoomScale = ThisDrawing.ActiveViewport.CustomScale
MsgBox CurrentZoomScale
I get the "Object doesn't support this property or method" error. Where can
I find this property?
Keith
John Goodfellow wrote in message
news:63BF1CAFDB0C2488D34FD0ACFC1F16AC@in.WebX.maYIadrTaRb...
> John Goodfellow
> irtf'nm
forced
> a
> variable
> > Keith
Message 4 of 16
Well, that was a guess. CustomScale is a property of the PViewport object
only. It may not be what you are looking for. I use it to read the scale
of a PViewport so I can adjust dimension line seperation distances back in
modelspace. Maybe you could work around the problem with the REGENAUTO
setting and the REGENMODE system variable?
John Goodfellow
irtf'nm
news:DA0CAD38F3978C282A7BAA6237D99740@in.WebX.maYIadrTaRb...
> When trying:
can
> Thanks,
> Keith
> > John Goodfellow
> > irtf'nm
some
> forced
> > a
> > variable
> > > Keith
Message 5 of 16
Well, thanks for the guess. Anyone else?
Turning the regenauto off still resulted in a regen when restoring the view.
Thanks anyways.
Surely the zoom previous gets its scale factor from somewhere.?.?.?
Keith
news:721C0284ACB4A5549CF56B1F502A8E6E@in.WebX.maYIadrTaRb...
> John Goodfellow
> irtf'nm
> > When trying:
> can
> > Thanks,
> > Keith
> > > John Goodfellow
> > > irtf'nm
> some
> > forced
> > > a
> > > variable
> > > > Keith
Message 6 of 16
Got this reply going through tech support (after 5 days):
>Thank you for contacting the Developer Consulting Group.
>I am sorry to say that the regeneration cannot be avoided while using the
activex methods. As a workaround you might look at using >the 'SendCommand'
method as follows:
>ThisDrawing.SendCommand "-view r viewname" & vbCr
Keith wrote in message
news:1625DCDBFD92A672E8794D05CDF8F02A@in.WebX.maYIadrTaRb...
view.
> Thanks anyways.
> Keith
object
scale
in
> > John Goodfellow
> > irtf'nm
> > > When trying:
Where
> > can
> > > Thanks,
> > > Keith
> > > > John Goodfellow
> > > > irtf'nm
> > some
active
> > > forced
> > > > a
am
Acad
> > > > variable
> > > > > Keith
Message 7 of 16
Now, I'm simply trying to determine which viewport is current so I can save
the correct variables to restore the view when my routine is finished. This
routine, when run with 3 viewports displayed, gives me the same result no
matter which viewport is active. I need help.
Sub whichviewport()
Dim vwprt As AcadViewport
Set vwprt = ThisDrawing.ActiveViewport
MsgBox "name: " & vwprt.Name & vbCr & "direction: x" &
vwprt.Direction(0) & " y" & vwprt.Direction(1) & " z" & vwprt.Direction(2)
& vbCr & "lower left: x" & vwprt.LowerLeftCorner(0) & " y" &
vwprt.LowerLeftCorner(0) & vbCr & "upper right: x" &
vwprt.UpperRightCorner(0) & " y" & vwprt.UpperRightCorner(1) & vbCr &
"viewport center: x" & vwprt.center(0) & " y" & vwprt.center(1)
End Sub
a
variable
> Keith
Message 8 of 16
Keith, I've been watching this thread for a while as it was along the same
lines as something that I have been trying to do with lisp. If you don't
want to actually save a view, then restore it, check out the thread
"Viewport Tools!" on 5/29/01 in nntp://autocesk.autocad.customization .
Specifically look at the functions (getViewData) and (putView). You'll
still have to use SendCommand, because it's a lisp routine, but at least you
won't have to actually save a view.
Bobby C. Jones
news:3A5BF385FE5422BDB5C602A286733D05@in.WebX.maYIadrTaRb...
'SendCommand'
> method as follows:
Message 9 of 16
that's nntp://autodesk.autocad.customization
Bobby C. Jones
Message 10 of 16
Thanks, Bobby
Those routines are not very long so I copied them here. Since that code is
Lisp, I don't understand it. Can this code be converted to VBA? It looks
like you extract the DXF group code values and use them. Is that correct?
Where do you determine the current viewport?
;;;Arguments - ActiveX Viewport object
;;;Retval - A list of data suitable to pass to
;;;the (setview) function
(defun getViewData (vlaObj / entlst)
(setq entlst (entget (vlax-vla-object->ename vlaObj)))
(mapcar '(lambda (x y) (cons x (cdr (assoc y entlst))))
'(40 10 11 12 42 43 44 50 110 111 112 79 146)
'(45 12 16 17 42 43 44 51 110 111 112 79 146)
) ;_ end of mapcar
) ;_ end of defun
;;;Arguments - ActiveX Viewport object;
;;;'view' data list as returned by (getViewData) or
;;;(tblsearch "view" viewName)
(defun putView (vlaObj viewData)
(setview viewData
(cdr (assoc 69 (entget (vlax-vla-object->ename vlaObj))))
) ;_ end of setview
) ;_ end of defun
Bobby Jones wrote in message
news:AC6EC3CBDCD376955B8FC3D4FC9D54DA@in.WebX.maYIadrTaRb...
you
> Bobby C. Jones
the
> 'SendCommand'
> > method as follows:
Message 11 of 16
Keith, My understanding of sharing info between VBA and lisp is limited, so
maybe someone could help us with that part, but I'll break down exactly
what's going on in these routines. First of all these routines are
utilities and therefore they do not retrieve the viewport objects
themselves, they are passed from another function. The first line of
getViewData:
defines the 'procedure' getViewData and sets the variable vlaObj, local to
the procedure, as an argument that will be passed to the procedure and sets
the scope of the variable entlst as local to the procedure. The procedure
expects a valid psViewport object to be passed to it and it will be assigned
to the vlaObj variable.
The next line converts the viewport object into an entity name that lisp
functions will understand, gets the DXF association list from the entity,
and assigns that information to the variable entlst
The next function takes the dxf association list of the viewport and
converts it into an association list that matches the association list of a
view entity with the same view as the viewport. It doesn't create the view,
it just gathers the information that the view would contain if it existed.
) ;_ end of mapcar
All lisp functions, or almost all, return a value. The getViewData function
returns the newly created data list of our imaginary view. The putView
function takes that data and applies it to another psViewport object so that
it changes the view to match. So you would call the putView something like
this:
(putView vpObjectToChangeView viewData)
They work together like so:
(setq viewData (getViewData vpObjectWithDesiredView))
(putView vpObjectToChange viewData)
or simply
(putView vpObjectToChange (getViewData vpObjectWithDesiredView))
Now what I don't know is how easy it is to pass viewport objects stored in
VBA variables to lisp functions. I'm not a VBA programmer, but I lurk in
this group because I do access the ActiveX object model via lisp and a lot
of what is discussed here in this NG applies to me also. I'm willing to bet
that someone knows how to make this work. Good luck
Bobby C. Jones
news:73A289740F2720A433CB5DEC1F10D7D5@in.WebX.maYIadrTaRb...
> Thanks, Bobby
is
> ) ;_ end of mapcar
> ) ;_ end of defun
> (setview viewData
> ) ;_ end of setview
> ) ;_ end of defun
Message 12 of 16
Your process sounds like what I'm after. I just need to know how to do it
in VBA. The lisp command vports returns a list of values representing the
'location' of each visible viewport window. The first in the list is the
current window:
"The current viewport's descriptor is always first in the list. In the
previous example, viewport number 5 is the current viewport."
Does anyone know how to get these 'descriptors' in VBA?
news:7CE0006E16B9116392FC627C2B62EF74@in.WebX.maYIadrTaRb...
so
> getViewData:
sets
assigned
a
view,
> ) ;_ end of mapcar
function
that
like
> this:
> or simply
bet
> Bobby C. Jones
> > Thanks, Bobby
> is
looks
correct?
> > ) ;_ end of mapcar
> > ) ;_ end of defun
> > (setview viewData
> > ) ;_ end of setview
> > ) ;_ end of defun
Message 13 of 16
Not sure this helps but a viewport has LowerLeftCorner and UpperRightCorner
properties in the form of 2D coords. Can those be used to do what you want
to do?
- Tom
news:0525426CC46EACDE978853D4FD84B946@in.WebX.maYIadrTaRb...
> current window:
Message 14 of 16
"> Does anyone know how to get these 'descriptors' in VBA?
The current viewport id number is stored in the cvport sysvar. If you are
working 'in' the viewport, panning and zooming and picking like you stated,
then simply grab the cvport value.
Bobby C. Jones
Message 15 of 16
Thanks, I knew those were available. I didn't know the sys var CVPORT was!
Tom Gilmer wrote in message
news:948C7D9721DBD3D3B6369A6AB09A6819@in.WebX.maYIadrTaRb...
UpperRightCorner
> to do?
> - Tom
it
the
the
> > current window:
Message 16 of 16
Thanks, Bobby. Didn't know about that one.
news:B1E5D5C5617FD8E916BA914FCCEF730E@in.WebX.maYIadrTaRb...
stated,
> Bobby C. Jones
