Zooming while in a VBA routine
Ok, I'm using A2K...
I start my VBA command and while I'm running the command, I need to be able
to zoom into other areas of my drawing. When I hit the zoom button on the
toolbar, it cancels my VBA.
Does anybody have a suggestion on how to overcome this?
CC
No, this is a known bug. If you like though, you can place buttons on your
form that will allow a user to zoom and pan around to where they need to be.
I had to do this on one of my projects. I drew an icon for each direction
and a zoom scale factor slide bar. This seemed to work ok but I wish
Autodesk would fix this. Transparent zooms still work if you type them at
the command prompt. Maybe this would be your answer. Instead of using the
icons, type'zoom a the command prompt. Hope this helps.
i found if type ' z or 'pan you can zoom and also if your mouse has the middle
button as wheel you can zoom in and out and pan
> Thanks
> CC
try to catch the error and use resume (and see the result)!!!!
sub Ciccio()
on error goto Herr
thisdrawing.utility.getentity Myobj,p1,"get an acadentity :"
herr:
resume
end sub
That seems to work but what if I want to catch the error to find out if the
user cancelled? Pressing 'esc' or 'return' returns the same error as
pressing a zoom icon. It looks like this would make it difficult to
determine the users intent.
I reassign my f12 key to be a 'pan. this is working fine. if you can right
click and change to real zoom or zoom extent from dialog. i get no crush.
> Thanks
> CC
