WithEvents Missing?
WithEvents Missing?
WithEvents Missing?
I have a variable in a Class Module declared as:
Dim WithEvents txtCell As TextBox
I need to use the Exit and/or BeforeUpdate Events, but these (and the Enter
and AfterUpdate) Events are not available to this variable.
How can I get these Events?
Note: I've checked in VB5.0 and Access 2000 VBA, and their TextBox has the
LostFocus and GotFocus Events available to a WithEvents variable.
Note: Acad 2002 VBA has the generic object Control that has only the 4
"missing" Events. Is this a coincidence? I tried assigning the TextBox to a
Control variable, but I get "Error #429 - object or class does not match the
set of events"
Does anybody know what's going on here??
DC Deno had this to say:
Simply placing a textbox on a form will give you access to all of it's
methods and properties. What's the deal with the global variable?
http://www.acadx.com
"If you want to be somebody else change your mind"
Yes, I have used a TextBox that way before, but I want to create an
unlimited number at runtime so I can have a table whose cells are edittable
in place, and appearance can be controlled seperately. The cell might also
be a ComboBox or a ToggleButton or a graphic etc.
This is not an unreasonable thing to do, is it?
> edittable in place, and appearance can be controlled seperately.
> The cell might also be a ComboBox or a ToggleButton or a graphic
> etc.
You will certainly be stretching the limits of what VBA is designed to
do. Are you sure you wouldn't be better served with a profesionally
designed grid control?
I gave up trying to find controls that will do what I want, but I am open to
suggestions
