Windows Common control
Message 1 of 9
having heck trying to use the windows common controls to use the showopen to
get a filename, but can't get it to work. Which file do I need to add a
reference to? There are multiple mscom files. Help.
Troy
Replies (8)
Message 2 of 9
Microsoft Windows Common Controls 6.0 is in C:\WINDOWS\SYSTEM\MSCOMCTL.OCX,
but the file open dialog is in Microsoft Common Dialog Control 6.0 (SP3)
C:\WINDOWS\SYSTEM\Comdlg32.ocx. Help file for the latter is in
C:\WINDOWS\HELP\CMDLG98.CHM.
John Goodfellow
irtf'nm
use 'microtouch' in address to email
"Troy Sigwing" wrote in message
news:A159B7FEC1D167B253BD78279D3AB9FD@in.WebX.maYIadrTaRb...
to
> Troy
Message 3 of 9
Unfortunately I get a message saying my help file is corrupt. When I
located it manually, I could open it, but cannot get to any of the linked
info, especially the examples. If anyone would be so kind as to post it
here...
eternally grateful
Troy
"John Goodfellow" wrote in message
news:D5825105E2B21D2DEB018AAB84881C01@in.WebX.maYIadrTaRb...
> John Goodfellow
> irtf'nm
showopen
> to
> > Troy
Message 4 of 9
The problem is that I don't have any forms to drop the commondialog control
onto, I am just writing a module, and I am going to load it into a button.
When the user clicks the button this program will run, and part of it needs
to activate the windows open dialog box, but I don't know how to do it
without the commondialog control. I guess windows API here I come.
to
> Troy
Message 5 of 9
Troy,
Why not just add a form to your project, which you can drop the common
dialog control onto, without ever making the form visible?
Andrew Wilford
www.artwork.com
Message 6 of 9
On Tue, 13 Mar 2001 14:43:59 -0800, "Troy Sigwing"
wrote:
»The problem is that I don't have any forms to drop the commondialog control
»onto, I am just writing a module, and I am going to load it into a button.
»When the user clicks the button this program will run, and part of it needs
»to activate the windows open dialog box, but I don't know how to do it
»without the commondialog control. I guess windows API here I come.
Visual Basic Common Control API Routines
Using the GetOpenFileName Common Dialog API
Paul Marshall
pmarshal@vulcraft-al.com
Message 7 of 9
Ok, I loaded it, but how do I get it to display the standard windows file
open dialog box? when I try to use it I get:
GetOpenFileName.GetOpenFileName
and I don't know what it is looking for after the last GetOpenFileName
Thanks again, I feel like such an idiot.
Troy
"Paul Marshall" wrote in message
news:5tnuat8h2vf0n22gj32cu2l4pb77t0g7j0@4ax.com...
control
button.
needs
> Paul Marshall
Message 8 of 9
Finally found the soloution I was looking for at http://www.acadx.com/
news:A59154C557A4375E0BD4C29224E4E2CC@in.WebX.maYIadrTaRb...
> Troy
> control
> button.
> needs
> > Paul Marshall
Message 9 of 9
On Wed, 14 Mar 2001 07:58:14 -0800, "Troy Sigwing"
wrote:
»Ok, I loaded it, but how do I get it to display the standard windows file
»open dialog box? when I try to use it I get:
»GetOpenFileName.GetOpenFileName
»and I don't know what it is looking for after the last GetOpenFileName
OK, now I'm confused.
Somewhere in your code, you should have something like:
Dim OFN As OPENFILENAME
With OFN
.nStructSize = Len(OFN)
'fill other needed elements of OFN
End With
If GetOpenFileName(OFN) Then
'success... process the returned file name(s)
If you're wanting a class which encapsulates this stuff, try this one
from From A.C.A.D (<>)
FileDialog.cls
Paul Marshall
