Why won't this initialize application event handlers?
In a class module (named: eventclass) I have the following:
Option Explicit
Public Sub AcadApp_SysVarChanged(ByVal SysvarName As String, ByVal newVal As
Variant)
Dim oldsf As Single
Dim newsf As Single
MsgBox "SysvarChanged event " & "Sysvar: " & SysvarName, vbOKOnly
oldsf = ThisDrawing.GetVariable("userr1")
Select Case SysvarName
Case Is = "Tilemode"
If newVal = 1 Then
newsf = MsgBox("New drawing scale factor(" & Format(oldsf,
"0,###.###") & "): ", _
vbOKOnly, "Tilemode changed")
Else
MsgBox "Tilemode turned off"
End Select
End Sub
and in the ThisDrawing module I have:
Dim AppEvents As New EventClass
Public WithEvents AcadApp As AcadApplication
Private Sub InitializeAppEvents()
Set AppEvents.AcadApp = ThisDrawing.Application
End Sub
Public Sub VBA_ini()
ThisDrawing.Utility.Prompt vbCrLf & "VBA system initialized. "
InitializeAppEvents
End Sub
with VBA_ini being called from my s::startup function.
What am I missing here?
I don't see where you've declared a variable of type AcadApplication
WithEvents in your class module. Also, you're taking a couple of extra
steps. The class module can gain a reference to the Application object
all by itself:
(in the class module)
Private WithEvents AcadApp As AcadApplication
Private Sub Class_Initialize()
Set AcadApp = AcadApplication
End Sub
Private Sub Class_Terminate()
Set AcadApp = Nothing
End Sub
Now all you have to do is create an instance of the class and it can
start handling events.
http://www.acadx.com
"Mike Weaver" wrote in message
news:0773E2A26049A5F67D4BC1F4F7BC684B@in.WebX.maYIadrTaRb...
Thanks for the response, Frank.
This just doesn't seem to be clicking for me yet. I pasted your code into
my class module and declared a variable in the class module:
Option Explicit
End Sub
End Sub
Private Sub AcadApp_SysVarChanged(ByVal SysvarName As String, ByVal newVal
As Variant)
Dim oldsf As Single
Dim newsf As Single
If newVal = 1 Then
"0,###.###") & "): ", vbOKOnly, "Tilemode changed")
Else
End Select
End Sub
So, I have the following in my declarations section of ThisDrawing:
Option Explicit
But I still don't get the msgbox specified in AcadApp_SysVarChanged.
I've tried the online help system but haven't been able to get this to work,
so I thank you, again, for your help.
Mike Weaver
"Frank Oquendo" wrote in message
news:7FDAE1B6A22F16E3FEE615930D9860C1@in.WebX.maYIadrTaRb...
> all by itself:
> End Sub
> End Sub
Try this:
(put this is a standard module)
Public e As AppEvents
Public Sub Startup()
Set e = New AppEvents
End Sub
Public Sub Shutdown()
Set e = Nothing
End Sub
(put this in a class module name AppEvents)
newVal As Variant)
MsgBox SysvarName & " was changed to " & newVal
End Sub
End Sub
End Sub
Run the Stratup macro to start handling application level events. Bear
in mind that not all sysvars will trigger an event (DBMOD comes to
mind). When you're ready to stop handling events, run the Shutdown
macro. Hope this helps.
news:C9F894116AB96512C66B0DB38C61B615@in.WebX.maYIadrTaRb...
code into
Thanks, Frank.
That works. Now I'll have to play around with it to see if I can see what
my problems were earlier.
Mike
news:B6A847059C58136CD2023442C258AE7E@in.WebX.maYIadrTaRb...
> Try this:
> End Sub
> Set e = Nothing
> End Sub
> newVal As Variant)
> End Sub
> End Sub
> End Sub
> code into
