why it takes so much time when saving a drawing after loading a dvb file
hi,
i am using 2005 to draw,but after i load a dvb file to use vba subs,
it takes me so much time to save a drawing ,
i mean the moment i save a drawing ,it seems that all loaded vba subs are
executed,
i dont know why,
for i used same vba in 2000i,there werent happenings like this,
what is the problem
thanks
arcticad
My almost-uneducated guess.
if you use an object modify event (reactor). When the drawing is saved in a non native format it will have to convert every object and the run the reactor thousands of times.
You need to have one dvb file unload the reactor code before you save the file.
(defun botsbuildbots() (botsbuildbots))
Thanks for your advice.
but i knew and i had looked for the bug and failed,
thanks
wrote in message news:5867201@discussion.autodesk.com...
file.
I've heard before that a good practice to do is....
every so often export all of the modules, forms, etc. and create a new blank dvb and import them. Can help reduce the compiled dvb size.
i typically use the VBUNLOAD command to remove any dvb files after i'm done with them.
