Why it's not working? (please help)
Message 1 of 13
I'm trying to check a polyline direction using the following code (found
here). Sometimes it works ok, but sometimes not (please see attached file).
Please help me!
Andre
Sub cw()
' based on lisp file from
';; ! Copyright: (C) 2000, Four Dimension Technologies, Singapore
';; ! Contact : rakesh.rao@4d-technologies.com for help/support/info
Dim objPline As Object, entBasePnt As Double
Dim varCoords As Variant
Dim i As Integer
Dim dbltemppt(0 To 1) As Double
Dim varVertexList As Variant
Dim intCoordCnt As Integer
Dim pt1 As Variant, pt2 As Variant
Dim Direction As Double, dblVertexCnt As Double, temp As Double
ThisDrawing.Utility.GetEntity objPline, entBasePnt, vbCr & "Select closed
Polyline: "
varCoords = objPline.Coordinates
i = 0
ReDim varVertexList(0 To ((UBound(varCoords) + 1) / 2))
For intCoordCnt = 1 To UBound(varCoords) Step 2
dbltemppt(0) = varCoords(intCoordCnt - 1)
dbltemppt(1) = varCoords(intCoordCnt)
varVertexList(i) = dbltemppt
i = i + 1
Next intCoordCnt
i = 0
dblVertexCnt = UBound(varVertexList)
While i < dblVertexCnt - 1
pt1 = varVertexList(i)
pt2 = varVertexList(i + 1)
Direction = Direction + (pt1(1) * pt2(0))
i = i + 1
Wend
pt1 = varVertexList(dblVertexCnt - 1)
pt2 = varVertexList(0)
i = 0: temp = 0
temp = temp + (pt1(1) * pt2(0))
i = i + 1
Wend
pt1 = varVertexList(0)
pt2 = varVertexList(dblVertexCnt - 1)
Direction = 0.5 * (Direction - temp)
If Direction > 0 Then MsgBox "CW"
If Direction < 0 Then MsgBox "CCW"
If Direction = 0 Then MsgBox "?"
End Sub
Replies (12)
Message 2 of 13
GTVic
I didn't follow your algorithm but I have one that is a bit more involved that should work... It uses trig functions so is slower but should be easy to follow.
[code]Option Explicit
Private Const M_PI = 3.14159265358979
Private Const M_PI_2 = 1.5707963267949
Private Type PointAngleType
x As Double
y As Double
AngleToNext As Double
End Type
Private Function GetAngle(x1 As Double, y1 As Double, x2 As Double, y2 As Double) As Double
Dim dX As Double, dY As Double, a As Double
dX = x2 - x1
dY = y2 - y1
If dX <> 0 Then
If dY <> 0 Then
a = Atn(dY / dX)
If dX < 0 Then a = a + M_PI
Do While (a < 0) Or (a >= (2# * M_PI))
a = a + (IIf(a < 0, 2#, -2#) * M_PI)
Loop
Else
If dX < 0 Then a = M_PI Else a = 0
ElseIf dY <> 0 Then
If dY > 0 Then a = M_PI_2 Else a = M_PI + M_PI_2
Else
a = 999 ' no angle, points are identical
GetAngle = a
End Function
Private Sub Direction()
Dim objPoly As AcadObject, dblBase(0 To 2) As Double, SumAngle As Double
Dim varCoords As Variant, dblPoints() As PointAngleType
Dim iStep As Integer, i As Long
On Error Resume Next
Err.Clear
ThisDrawing.Utility.GetEntity objPoly, dblBase, vbCr & "Select closed polyline: "
If Err.Number = 0 Then
On Error GoTo 0
If objPoly.ObjectName = "AcDbPolyline" Or objPoly.ObjectName = "AcDb2dPolyline" Then
iStep = IIf(objPoly.ObjectName = "AcDbPolyline", 2, 3)
varCoords = objPoly.Coordinates
For i = LBound(varCoords) To UBound(varCoords) Step iStep
ReDim Preserve dblPoints(0 To (i / iStep)) As PointAngleType
dblPoints(i / iStep).x = varCoords(i)
dblPoints(i / iStep).y = varCoords(i + 1)
Next i
If objPoly.Closed Then
dblPoints(i / iStep).x = varCoords(0)
dblPoints(i / iStep).y = varCoords(1)
For i = LBound(dblPoints) To UBound(dblPoints) - 1
dblPoints(i).AngleToNext = GetAngle(dblPoints(i).x, dblPoints(i).y, dblPoints(i + 1).x, dblPoints(i + 1).y)
Next i
' compare each segment angle to the next
' if the turn is to the right then add the turn angle to the total
' if the turn is to the left then subtract
SumAngle = 0#
For i = LBound(dblPoints) To UBound(dblPoints) - 2
If dblPoints(i).AngleToNext <> 999 Then
If dblPoints(i + 1).AngleToNext <> 999 Then
If Abs(dblPoints(i + 1).AngleToNext - dblPoints(i).AngleToNext) < 0.0000000001 Then
' angles in exact same direction = straight
SumAngle = SumAngle + 0#
ElseIf Sin(dblPoints(i).AngleToNext) + Sin(dblPoints(i + 1).AngleToNext) < 0.0000000001 Then
' angles in exact opposite direction = straight back
ElseIf (dblPoints(i + 1).AngleToNext < dblPoints(i).AngleToNext) Then
If (dblPoints(i + 1).AngleToNext > (dblPoints(i).AngleToNext - M_PI)) Then ' right
SumAngle = SumAngle + (dblPoints(i).AngleToNext - dblPoints(i + 1).AngleToNext)
Else ' left
SumAngle = SumAngle - (M_PI + M_PI - dblPoints(i).AngleToNext + dblPoints(i + 1).AngleToNext)
Else ' next angle is greater than this angle
If dblPoints(i + 1).AngleToNext < (dblPoints(i).AngleToNext + M_PI) Then ' left
SumAngle = SumAngle - (dblPoints(i + 1).AngleToNext - dblPoints(i).AngleToNext)
Else ' right
SumAngle = SumAngle + (dblPoints(i).AngleToNext + M_PI + M_PI - dblPoints(i + 1).AngleToNext)
Else
' two consecutive points at the same location - use the last angle for the next calculation
dblPoints(i + 1).AngleToNext = dblPoints(i).AngleToNext
Next i
If SumAngle > 0 Then ' more right turns than left
MsgBox "Polygon is clockwise ", vbInformation, IIf(objPoly.Closed, "Closed Polyline", "Polyline is not Closed")
ElseIf SumAngle < 0 Then ' more left turns than right
MsgBox "Polygon is counterclockwise ", vbInformation, IIf(objPoly.Closed, "Closed Polyline", "Polyline is not Closed")
Else ' direction could be either
MsgBox "Could not determine direction ", vbInformation, IIf(objPoly.Closed, "Closed Polyline", "Polyline is not Closed")
Else
MsgBox "Object is not a polyline ", vbInformation, "Message"
Else
On Error GoTo 0
End Sub[/code] Message was edited by: GTVic
Message 3 of 13
This is what I use to calculate areas
Its sign happens to depend on the direction of the polyline
so it might be what your looking for.
I haven't done extensive checking on the sign so I can't be
100% sure it's going to work for all cases
I leave the testing to you.
Sub POLDIR()
Dim polcoor As Variant
Dim epol As AcadLWPolyline
Dim esel As AcadSelectionSet
Dim fdatat(0) As Integer
Dim fdatav(0) As Variant
Dim i As Long
Dim j As Long
Dim cx() As Double
Dim cy() As Double
Dim Ctot1 As Double
Set esel = ThisDrawing.SelectionSets.Add("selpol")
If Err.Number <> 0 Then
Set esel = ThisDrawing.SelectionSets("selpol")
esel.Clear
fdatat(0) = 0
fdatav(0) = "LWPOLYLINE"
esel.SelectOnScreen fdatat, fdatav
Do While esel.Count > 0
Set epol = esel.Item(0)
polcoor = epol.Coordinates
ReDim cx((UBound(polcoor) + 1) / 2)
ReDim cy((UBound(polcoor) + 1) / 2)
j = 0
For i = 0 To UBound(polcoor) Step 2
cx(j) = polcoor(i)
cy(j) = polcoor(i + 1)
j = j + 1
Next i
Ctot1 = 0
For i = 0 To UBound(cx) - 1
Ctot1 = Ctot1 + (cx(i + 1) * cy(i))
Ctot1 = Ctot1 - (cx(i) * cy(i + 1))
Next i
Ctot1 = Ctot1 + (cx(0) * cy(UBound(cy) - 1))
Ctot1 = Ctot1 - (cx(UBound(cx) - 1) * cy(0))
If Ctot1 < 0 Then
MsgBox "Direction is CCW"
Else
MsgBox "Direction is CW"
esel.Clear
Loop
End Sub
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
"André Dantas Rocha "
<=?UTF-8?Q?Andr=C3=A9_Dantas_Rocha_?=> wrote in message
news:4862806@discussion.autodesk.com...
Please help me!
Andre
Sub cw()
Dim i As Integer
Dim v
Polyline: "
i = 0
varVertexList(i
) = dbltemppt
i = i + 1
Next intCoordCnt
i = 0
i = i + 1
Wend
i = 0: temp = 0
i =
i + 1
Wend
End Sub
Message 4 of 13
Just a flash: Why not check the Normal property of a polyline?
Message 5 of 13
Because the normal is a vector perpendicular to the entitie's plane.
The plane does not have anything to do with the polyline's direction
wrote in message news:4862947@discussion.autodesk.com...
Message 6 of 13
Yeah you're right 😞
Normal property (with plines) points in the direction of the Z axis, when the pline was drawn. This means if you drew it from bottom view then the 3rd value of the Normal vector is negative.
If I understand correctly, you are trying to find out, if a polyline was drawn clockwise?
Hope you sorted this out already, if not, try to search on the web. Here's one I found:
http://forum.java.sun.com/thread.jspa?threadID=564806&tstart=135
Message 7 of 13
Actually, I posted that same method
in answer to Andre´s post
wrote in message news:4863718@discussion.autodesk.com...
Yeah you're right 😞
drawn clockwise?
one I found:
Message 8 of 13
Thank you very much GTVic. The function works well!!!
escreveu na mensagem news:4862922@discussion.autodesk.com...
to follow.
x As Double
y As Double
End Type
Double) As Double
dX = x2 - x1
dY = y2 - y1
If dX <> 0 Then
If dY <> 0 Then
a = Atn(dY / dX)
Loop
Else
ElseIf dY <> 0 Then
Else
GetAngle = a
End Function
Err.Clear
polyline: "
On Error GoTo 0
Next i
Next i
total
SumAngle = 0#
back
Else ' left
Else ' right
Else
Next i
Else
Else
On Error GoTo 0
End Sub[/code]
Message 9 of 13
Thank you very much Jorge. The function works well!!!
"Jorge Jimenez" escreveu na mensagem
news:4862954@discussion.autodesk.com...
Sub POLDIR()
Dim i As Long
Dim j As Long
Dim cx() As Double
Dim cy() As Double
Dim Ctot1 As Double
esel.Clear
fdatat(0) = 0
j = 0
cx(j) = polcoor(i)
j = j + 1
Next i
Ctot1 = 0
Next i
If Ctot1 < 0 Then
Else
esel.Clear
Loop
End Sub
Please help me!
Andre
Sub cw()
Dim i As Integer
Dim v
Polyline: "
i = 0
varVertexList(i
) = dbltemppt
i = i + 1
Next intCoordCnt
i = 0
i = i + 1
Wend
i = 0: temp = 0
i =
i + 1
Wend
End Sub
Message 10 of 13
GTVic
Jorge, if this is the same algorithm as in the link below then it should work as long as the polygon does not intersect itself. The algorithm I posted is not as efficient but should work in any case (even if the polyline is not closed).
http://astronomy.swin.edu.au/~pbourke/geometry/polyarea/
Message 11 of 13
Haven't tested yours, but I'm sure it must do a good job.
But you see, there is no sense in finding the direction of a selft
intersecting poligon.
Say a bowtie for example, is has both directions !! one half is CCW and the
other is CW.
And anyway, there is always a way to use the algorithm I posted
Just find the intersection point and check for just the correct set of
vertices.
wrote in message news:4864383@discussion.autodesk.com...
is not closed).
Message 12 of 13
GTVic
True, but there are cases where it can itersect and yet still be defined as CW or CCW ... for example if it crosses itself and then crosses back. Maybe as long as the number of intersections is even then a valid CW/CCW can still be found (just an hypothesis since I haven't bothered to check).
Message 13 of 13
Well you see, normally the direction info is useful for some analysis
in land, surveying and GIS applications, and probably for CNC too
and usually the type of polygon you're dealing with in these cases
can not and should not intersect with itself..
wrote in message news:4865470@discussion.autodesk.com...
