Why do I get an Endless loop?
The following code gets stuck in an endless
loop?  It happens in the "Public Sub ListFilesInFolder(folder As
Scripting.folder)" section.
WATCH word wrap.
Option Explicit
Dim intcount As Integer
Dim
ACADApp As AcadApplication
Dim strSubdirectories As String
Public Sub ProcessFolder(path As
String)
    Dim fso As FileSystemObject,
folder As Scripting.folder
    Dim f As
Scripting.folder
    Set fso = New
FileSystemObject
    Set f =
fso.GetFolder(path)
    ListFilesInFolder f
End Sub
Scripting.folder)
    Dim file As Scripting.file, f As
folder
    For Each file In
folder.Files
        If
LCase(GetAnExtension(file)) = "dwg"
Then
        Dim newtxtstyle As
AcadTextStyle
        Dim stdtxtstyle As
AcadTextStyle
            If
intcount = 0
Then
            Set
ACADApp =
ThisDrawing.Application
ACADApp.Documents.Close
        End
If
        Application.Documents.Open
file
        Set stdtxtstyle =
ThisDrawing.TextStyles.Item("STANDARD")
'    Set newtxtstyle =
ThisDrawing.TextStyles.Item("BOLD6")
'    newtxtstyle.fontFile =
"C:\Windows\Fonts\swiss.ttf"
'    ThisDrawing.Regen
(True)
ThisDrawing.ActiveTextStyle =
stdtxtstyle
'        stdtxtstyle.fontFile
= "romans.shx"
        ThisDrawing.Regen
(True)
ThisDrawing.PurgeAll
ZoomExtents
'        Dim AcadX As
AcadXApplication
'        Set AcadX =
GetInterfaceObject("AcadX.Application")
ThisDrawing.Activate
AcadX.MakePreviewImage ThisDrawing
ThisDrawing.Save
ThisDrawing.Close
        intcount =
intcount + 1
        End
If
    Debug.Print file.path
Next
    If strSubdirectories = "1"
Then
        For Each f In
folder.SubFolders
Call ListFilesInFolder(f)
Next
End Sub
Public Sub Purge()
    Dim
strFolder As String
    intcount = 0
strFolder = GetSetting("AutoCAD", "Purge Folder",
"Folder")
    strSubdirectories = GetSetting("AutoCAD", "Purge
Folder", "Subdirectory")
    If strFolder = ""
Then
        MsgBox "You must set a folder
to be purged.", vbInformation, "Set
Directory"
        Exit
Sub
    Call
ProcessFolder(strFolder)
    SaveSetting ACADApp.Name, "Purge
Count", "Number", CStr(intcount)
End Sub
Function GetAnExtension(DriveSpec)
  Dim
fso
  Set fso = CreateObject("Scripting.FileSystemObject")
GetAnExtension = fso.GetExtensionName(DriveSpec)
End Function
Private Sub Set_Folder()
    SaveSetting "AutoCAD", "Purge
Folder", "Folder", "C:\Gibco - Invitrogen\Drawings\Parts\Tubing"
End Sub
Dave Gardner
(remove na. to reply)
"It's never too late to be what you might have
been."
George Eliot
Probably because of this
Then
        For Each f In
folder.SubFolders
Next
I don't see where is being assigned a value to
come out of the loop.
Saludos,  Ing. Jorge Jimenez, SICAD
S.A., Costa Rica
WATCH word wrap.
Option Explicit
Dim
String)
    Dim f As
Scripting.folder
    Set fso = New
FileSystemObject
    Set f =
fso.GetFolder(path)
    ListFilesInFolder f
End Sub
Scripting.folder)
As folder
    For Each file In
folder.Files
        If
Then
        Dim newtxtstyle As
AcadTextStyle
        Dim stdtxtstyle As
AcadTextStyle
            If
intcount = 0
Then
            Set
ACADApp =
        End
If
file
        Set stdtxtstyle =
'    Set newtxtstyle =
'    ThisDrawing.Regen
(True)
stdtxtstyle
stdtxtstyle.fontFile =
"romans.shx"
        ThisDrawing.Regen
(True)
ZoomExtents
'        Dim AcadX As
AcadXApplication
'        Set AcadX =
ThisDrawing
ThisDrawing.Save
ThisDrawing.Close
        intcount =
intcount + 1
        End
If
Next
Then
        For Each f In
folder.SubFolders
Next
End Sub
Public Sub Purge()
    Dim
strFolder As String
    intcount = 0
"Folder")
"Purge Folder", "Subdirectory")
    If strFolder = ""
Then
folder to be purged.", vbInformation, "Set
Directory"
        Exit
Sub
    Call
"Purge Count", "Number", CStr(intcount)
End Sub
  Dim
fso
End Function
End Sub
Dave Gardner
been."
George Eliot
