Which Flag Is Set (ie 1, 2, 4,16,32,64,...)
I'm working with some code that deals with the layer states and the optional flag to determine which props to save.
Initially, I was going to store the sum of the flags using savesettings, until i realized I don't know how to "parse" the total into the individual flags. Could someone give a hint or a little code?
Edit: I need to figure out which flags are set so that i can mark the appropriate check box (just like the options for the native layer states)
Here are the codes I'm working with
acLsNone 0
acLsOn 1
acLsFrozen 2
acLsLocked 4
acLsPlot 8
acLsNewViewport 16
acLsColor 32
acLsLineType 64
acLsLineWeight 128
acLsPlotStyle 256
acLsAll 65535
TIA!
Message was edited by: Oberer
If RetrievedValue And acLsFrozen Then
'acLsFrozen bit is set
If RetrievedValue And acLsColor Then
'acLsColor bit is set
Hi Oberer This function returns the bitwise AND: [code] Public Function MeBitwAnd(FstVal As Integer, NxtVal As Integer) As Boolean MeBitwAnd = (((FstVal And NxtVal) = NxtVal) Or (FstVal = 0)) End Function [/code] Samples: ?MeBitwAnd(9, 8) True ?MeBitwAnd(9, 2) False Cheers -- Juerg Menzi MENZI ENGINEERING GmbH, Switzerland http://www.menziengineering.ch
I obviously didn't realize it was that simple 🙂
thanks!
