What's wrong with this code
Message 1 of 10
I'm trying to nest a xref in a block. The code I wrote adds a line first, it
inserts a xref in the drawing but it does not nest it in the block. What do
I do wrong?
Thanks in advance,
Jan Appelman
LENGKEEK architecten en ingenieurs
Public Sub Nest_ExternalReference()
Dim InsertPoint(0 To 2) As Double
Dim PathName As String
' Define external reference to be inserted
InsertPoint(0) = 1: InsertPoint(1) = 1: InsertPoint(2) = 0
PathName = "p:\project\wijnreno\wrlogo.dwg"
' add block with nema "strStempel" to blockscollection
Dim objBlk As AcadBlock
Set objBlk = ThisDrawing.Blocks.Add(InsertPoint, "strStempel")
' add line to block
Dim entline As AcadLine
Dim stp(0 To 2) As Double
Dim eip(0 To 2) As Double
stp(0) = 0: stp(1) = 0: stp(2) = 0
eip(0) = 5: eip(1) = 5: eip(2) = 0
Set entline = objBlk.AddLine(stp, eip)
' add xref to block
Dim xrefLogo As AcadExternalReference
Set xrefLogo = objBlk.AttachExternalReference(PathName, "logo",
InsertPoint, 1#, 1#, 1#, 0, True)
' insert block
Dim blockRef As AcadBlockReference
Set blockRef = ThisDrawing.ModelSpace.InsertBlock(InsertPoint,
"strStempel", 1#, 1#, 1#, 0)
' Zoom all
ThisDrawing.Application.ZoomAll
End Sub
Replies (9)
Message 2 of 10
I don't think it's possible to create a block definition with an
external reference as a member.
http://www.acadx.com
"You keep using that word. I do not think it means what you think it
means."
"Jan Appelman" wrote in message
news:824C0090298E5E385D39D7A062F53B61@in.WebX.SaUCah8kaAW...
> Hello,
first, it
What do
> I do wrong?
Message 3 of 10
This is a little sub that I use for calculating mass of circular objects.
Public Sub Circle()
Dim d As Double
Dim h As Double
On Error GoTo ErrorControl
d = txtDiameter.Text
h = txtHeight.Text
txtMass.Text = (((pi * d * d / 4) * h) / 1000000000)
Exit Sub
ErrorControl:
If txtDiameter.Text = "" Then
MsgBox "Enter Diameter!", vbOKOnly, "Error Control"
txtDiameter.SetFocus
ElseIf txtHeight.Text = "" Then
MsgBox "Enter Height!", vbOKOnly, "Error Control"
txtHeight.SetFocus
End Sub
I believe that it works OK if I enter values for Diameter and Height larger
then "8" (I'm nott 100% sure I didn't try all the numbers). But if the
number is smaller then "8" it doesn't return the correct value. It's much
bigger then it should be.
What is wrong here? Should I declare "d" and "h" as something else then
Double.
Thanks, Marko.
Message 4 of 10
What are you using for the value of Pi?
Pi = Atn(1) * 4
Joe
Marko Rogic wrote in message
news:C9242FE8D3165510EB5201C4F4FF63F4@in.WebX.maYIadrTaRb...
> Public Sub Circle()
> Dim d As Double
> Dim h As Double
> h = txtHeight.Text
> Exit Sub
> ErrorControl:
> txtHeight.SetFocus
> End If
> End Sub
larger
> Double.
> Thanks, Marko.
Message 5 of 10
I've declared it like this:
Public Const pi As Double = 3.141592654
"Joe Sutphin" wrote in message
news:63C5392CB589E89933D452EADF049567@in.WebX.maYIadrTaRb...
> Pi = Atn(1) * 4
> Joe
objects.
> > Public Sub Circle()
> > Dim d As Double
> > Dim h As Double
> > h = txtHeight.Text
> > Exit Sub
> > ErrorControl:
> > txtHeight.SetFocus
> > End If
> > End Sub
> larger
much
> > Double.
> > Thanks, Marko.
Message 6 of 10
Then I would change that declaration to this
pi = Atn(1) * 4
Joe
news:103C1B846966B4E9CC0378696ADC8028@in.WebX.maYIadrTaRb...
> > Pi = Atn(1) * 4
> > Joe
> objects.
> > > Public Sub Circle()
> > > Dim d As Double
> > > Dim h As Double
> > > h = txtHeight.Text
> > > Exit Sub
> > > ErrorControl:
> > > txtHeight.SetFocus
> > > End If
> > > End Sub
> > larger
> much
then
> > > Double.
> > > Thanks, Marko.
Message 7 of 10
Thanks for the tip I'll try it tommorow at work.
Message 8 of 10
Arghhhh, how stupid can I be. The program worked just fine all along. But
because my text box for result wasn't big enough, I didn't see the very end
of result where the "E-04" or whatever was situated.
Which brings me to another question, how do you control the precision.
news:C1DE4C67D6C56C1F7A9695538F8B694D@in.WebX.maYIadrTaRb...
> pi = Atn(1) * 4
> Joe
> > > Pi = Atn(1) * 4
> > > Joe
> > objects.
> > > > Public Sub Circle()
> > > > Dim d As Double
> > > > Dim h As Double
> > > > h = txtHeight.Text
> > > > Exit Sub
> > > > ErrorControl:
> > > > txtHeight.SetFocus
> > > > End If
> > > > End Sub
> > > larger
the
> > much
> then
> > > > Double.
> > > > Thanks, Marko.
Message 9 of 10
You 'd best look in the VBA Help for the Format function and example.
MyStr = Format(5459.4, "##,##0.00") ' Returns "5,459.40".
Henk
Message 10 of 10
Thanks Henk.
"Henk Loonstra" wrote in message
news:0785D5457C092E69222D64421326858C@in.WebX.maYIadrTaRb...
> Henk
