What do I do now?
What do I do now?
What do I do now?
I had never used the User variables before, and so I checked out Useri1 and saw
that it was saved in the drawing. I foolishly figured the other User variables
were also, and got most of the way thru my program before I tried saving the
drawing and reopening it. Of course I found that Users variables aren't saved.
(Why the heck aren't they?)
Anyhow how do you save strings in a drawing, to be easily accessable by the
program every time?
Kent Keller
Check out the Mechanical Desktop FAQ @
http://webhome.idirect.com/~dfulford/
Kent,
Why not with XDATA ?
Bernard
Kent Keller a écrit dans le message :
221D97E7C41E3E0132FF7B8261ED7352@in.WebX.SaUCah8kaAW...
and saw
variables
the
saved.
the
> program every time?
> Kent Keller
Bernard
I have never dealt with XDATA (that I know of anyhow) Is it pretty easy to
work with? I will have to do some studying on it tomorrow, To late tonight 8)
Thanks for the suggestion.
Kent Keller
"Bernard Flavignard" wrote in message
news:B679AA88056C0F0B06EBD434338E91ED@in.WebX.SaUCah8kaAW...
> Kent,
> Bernard
Kent,
I do only one example for this, but you can look the Vlisp help and surch
XDATA, i think you can work with this. With an object, you can input XDATA
with the setxdata method and read it with the getxdata method
From the help
Sub Example_SetXdata()
' This example creates a line and attaches extended data to that line.
' Create the line
Dim lineObj As AcadLine
Dim startPt(0 To 2) As Double, endPt(0 To 2) As Double
startPt(0) = 1#: startPt(1) = 1#: startPt(2) = 0#
endPt(0) = 5#: endPt(1) = 5#: endPt(2) = 0#
Set lineObj = ThisDrawing.ModelSpace.AddLine(startPt, endPt)
ZoomAll
' Initialize all the xdata values. Note that first data in the list
should be
' application name and first datatype code should be 1001
Dim DataType(0 To 9) As Integer
Dim Data(0 To 9) As Variant
Dim reals3(0 To 2) As Double
Dim worldPos(0 To 2) As Double
DataType(0) = 1001: Data(0) = "Test_Application"
DataType(1) = 1000: Data(1) = "This is a test for xdata"
DataType(2) = 1003: Data(2) = "0" ' layer
DataType(3) = 1040: Data(3) = 1.23479137438413E+40 ' real
DataType(4) = 1041: Data(4) = 1237324938 ' distance
DataType(5) = 1070: Data(5) = 32767 ' 16 bit Integer
DataType(6) = 1071: Data(6) = 32767 ' 32 bit Integer
DataType(7) = 1042: Data(7) = 10 ' scaleFactor
reals3(0) = -2.95: reals3(1) = 100: reals3(2) = -20
DataType(8) = 1010: Data(8) = reals3 ' real
worldPos(0) = 4: worldPos(1) = 400.99999999: worldPos(2) = 2.798989
DataType(9) = 1011: Data(9) = worldPos ' world space
position
' Attach the xdata to the line
lineObj.SetXData DataType, Data
' Return the xdata for the line
Dim xdataOut As Variant
Dim xtypeOut As Variant
lineObj.GetXData "", xtypeOut, xdataOut
End Sub
Bernard
4A3F83D4B01A2EF58C760813833A24D5@in.WebX.SaUCah8kaAW...
> Bernard
to
tonight 8)
> Kent Keller
> > Kent,
> > Bernard
You're better off using xdata (for appliation data that is entity-specific)
or dictionaries (for application data that is drawing-specific).
Attitudes are contagious. Is yours worth catching?
http://www.acadx.com
"Kent Keller" wrote in message
news:221D97E7C41E3E0132FF7B8261ED7352@in.WebX.SaUCah8kaAW...
and saw
variables
the
saved.
the
> program every time?
> Kent Keller
