VBA repeats last command
I have a VBA form. When the user exiting the form it repeats the last command. It happens only for some users. How to fix this.
I hope it somehow passes a space or enter on some machines to repeat the last command.
Shijith
Edited by: spu on Feb 2, 2009 2:55 PM
Hi Shijith,
Run the code from the VBA editor and step through the code for the
control you use to close the form.
If there is no repeat actions there, then the repeat must come form the
menu call you are using to start the program. Look in your CUI file for
the repeat call, or the lisp program called by the menu call (if that's
the way you do it)
Regards
Laurie Comerford
spu wrote:
> Hi, I have a VBA form. When the user exiting the form it repeats the
> last command. It happens only for some users. How to fix this. I hope it
> command. Regards, Shijith Edited by: spu on Feb 2, 2009 2:55 PM
