VBA question reguarding syntax
mid-awe
Message 1 of 11
mid-awe
I'm very new to VBA and I'm still struggling with simple syntax issues. That said I admit that I'm stupid about this and I'm asking for help please?
I'm writing a VBA app to open a simple dialogue with Checkboxes and Option buttons which settings determine the electrical and plumbing schematic block is to be inserted into a drawing. Then, the correct AUTOLISP command is compiled and output to the Command line while exiting the dialogue.
This all works fine until I need to check if two or more statements are true at the same time. I tried to use a if, and, then, elseif, else statement but is doesn't seem to recognize the statement at all? here is an example:
Function GetEQ()
If SpaOnly And Raised = True Then
EQ$ = "RSWV"
ElseIf PoolSpa And PCC = True Then EQ$ = "PCS"
ElseIf PoolOnly And PCC = True Then EQ$ = "PC2"
ElseIf SpaOnly And Vac = True Then EQ$ = "SWV"
ElseIf PoolOnly = True Then EQ$ = "NP"
ElseIf SpaOnly = True Then EQ$ = "SWV"
ElseIf PoolSpa = True Then EQ$ = "PAS"
Else
PoolOnly = False: SpaOnly = False: Raised = False: Vac = False: PVal = False: NoBooster = False: PCC = False: Att = False: Sepr = False: SpaB = False: TwoSkims = False: Frog = False: Salt = False: DiChlor = False: WfBooster = False: Wfall = False: ShDescent = False: PcLay = False: SpLay = False
End Function
Any and all help with this likely to be easy question is greatly appreciated. Thanks.
Replies (10)
Message 2 of 11
[pre]
1. Your function needs a return type (and it needs to return something).
2. A function named GetEQ should only return a single value. It should not
change the values of a bunch of other (I assume global) variables.
Public Function GetEQ() As String
If SpaOnly And Raised Then
GetEQ = "RSWV"
ElseIf PoolSpa And PCC Then
GetEQ = "PCS"
ElseIf PoolOnly And PCC Then
GetEQ = "PC2"
ElseIf SpaOnly And Vac Then
GetEQ = "SWV"
ElseIf PoolOnly Then
GetEQ = "NP"
ElseIf SpaOnly Then
GetEQ = "SWV"
ElseIf PoolSpa Then
GetEQ = "PAS"
Else
GetEQ = ""
End Sub
To use: EQ$ = GetEQ
[/pre]
Message 3 of 11
mid-awe
Thank you very much that is an interesting structure, but I Think my code is too BASIC and not enough VBA 🙂
In the line, "If SpaOnly And Raised = True Then
EQ$ = "RSWV"" RSWV is the actual LISP command that I want to enter at the command line of AutoCAD. I put it together like this:
___________________
Private Sub CommandButton1_Click()
GetEQ ;;find equipment schematic
GetLay ;;find layer to insert to
EQ$ = "I" + EQ$ + Lay$ ;; make LISP command
ThisDrawing.SendCommand EQ$ + " " ;;insert command followed by space (enter)
UserForm1.Hide ;;close dialogue
End Sub
__________________________
It is working. Yet, I had hoped to find a better way of finding the correct string data to send. We have many schematics to sort through. It seems overly cumbersome doing it my way.
Message was edited by: MiD-AwE
Message 4 of 11
Can you zip up your VBA project (*.dvb file) and a sample drawing with all of the blocks defined and attach it (if under 1MB)? If the zipped file is too large, email it to me at Jack_Rabbit@NOSPAM.excite.com
I'll have a look and see if I can't provide some help.
Message 5 of 11
mid-awe
Thank you,
I appreciate the offer but I got it working.
Message 6 of 11
mid-awe
I'd like to add a msgbox that will notify the user if the schematic they are looking for doesn't exists in the list.
Can anyone help this is what I have but it doesn't work. What am I forgetting?
Dim SpaOnly As Boolean
Dim PoolOnly As Boolean
Dim PoolSpa As Boolean
Dim Msg, Style, Title, Response
Function GetEQ()
EQ$ = "RSWV"
Else
EQ$ = " "
End Function
GetEQ
If EQ$ = " " Then
Msg = "Sorry, Schematic Unavalable"
Style = vbOKOnly + vbCritical
Title = "Unavailable Schematic !"
Response = MsgBox(Msg, Style, Title)
If I paste the code into a command button it works fine. Why does it fail in the above code? Thanks again.
Message 7 of 11
This works for me:
[pre]
Public Sub Test01()
Dim BlockName As String
Dim ErrorMessage As String
Dim Response As Integer
Dim Title As String
BlockName = ""
If BlockName = "" Then
ErrorMessage = "Sorry, Schematic Unavalable"
Title = "Unavailable Schematic"
Response = MsgBox(ErrorMessage, vbCritical, Title)
End Sub
[/pre]
Message 8 of 11
It has to do with variable scope. If you paste all the code together, it all has access to EQ$, (BTW, I don't see it Dim'd anywhere). But when you call the function, you are expecting EQ$ to be set and it isn't. Have your function return the value and then use it to set a var, e.g. Inside the function, at the end: GetEQ = EQ$ BTW, change your function's signature to declare the return value's type: Function GetEQ () As String Then when you call the function, set your var: EQ$ = GetEQ() If EQ$ = " " Then -- ---- Ed ---- "MiD-AwE" wrote in message news:20949046.1103301373463.JavaMail.jive@jiveforum2.autodesk.com... > I'd like to add a msgbox that will notify the user if the schematic they are looking for doesn't exists in the list. > > Can anyone help this is what I have but it doesn't work. What am I forgetting? > > Dim SpaOnly As Boolean > Dim PoolOnly As Boolean > Dim PoolSpa As Boolean > Dim Msg, Style, Title, Response > > Function GetEQ() > If SpaOnly And Raised = True Then > EQ$ = "RSWV" > ElseIf PoolSpa And PCC = True Then EQ$ = "PCS" > ElseIf PoolOnly And PCC = True Then EQ$ = "PC2" > ElseIf SpaOnly And Vac = True Then EQ$ = "SWV" > ElseIf PoolOnly = True Then EQ$ = "NP" > ElseIf SpaOnly = True Then EQ$ = "SWV" > ElseIf PoolSpa = True Then EQ$ = "PAS" > Else > EQ$ = " " > End If > End Function > > GetEQ > If EQ$ = " " Then > Msg = "Sorry, Schematic Unavalable" > Style = vbOKOnly + vbCritical > Title = "Unavailable Schematic !" > Response = MsgBox(Msg, Style, Title) > End If > > If I paste the code into a command button it works fine. Why does it fail in the above code? Thanks again.
Message 9 of 11
mid-awe
Hey thanks, I think I understood most of what you said. Except the last part:
"Then when you call the function, set your var:
EQ$ = GetEQ()
If EQ$ = " " Then"
Where do I put this? Thanks again.(this is my first VBA project ever so please be kind).
Message 10 of 11
The second line is the beginning of your If...then statement in your first post. The first line just sets EQ$, which wasn't getting set before. -- ---- Ed ---- "MiD-AwE" wrote in message news:14697330.1103320779295.JavaMail.jive@jiveforum1.autodesk.com... > Hey thanks, I think I understood most of what you said. (this is my first VBA project ever so please be kind). Except the last part: > > "Then when you call the function, set your var: > EQ$ = GetEQ() > If EQ$ = " " Then" > > Where do I put this? Thanks again.
Message 11 of 11
mid-awe
This works great, but once the message displays and the user clicks the "OK" button the app closes automatically. How do I tell it to continue the app instead?
Thank you.
