VBA Programming To Get Line Point
VBA program to read Line point dxf file?
please help this.
data this point im attachment.
Thanks.
I'm afraid you should add some more details to your question
my understanding is that you need some VBA code to run from within an AutoCAD session that reads a file (is it a dxf file, as per your narrative, or a txt file as per your attached example?) and looks up for some point (ex "Pt29") to be used somehow
clarify and add whatever code you've come up to
Can you help me?
hopefully, yes
but you need to add more details to your question (see my previous post) and share your code attempts
Can i take your WhatApp number?
Nope
Let's keep it in this forum and enhance your question with all needed details and code attempts from your part
While if you don't know VBA at all then you'd better start with one of many VBA classes you can easily find in the web just googling them
Can you make VBA programming to get line point from this DXF Files, because i want to make Process Planning (CAPP) basis feature for Turning Machine  from this drawing. Can you help me..? I Hope You help me.
