Vba program removed when autocad restarts
I insert my program in in vba in autocad,
When i restart my Autocad i need to add my vba program again.
I dont know why my vba program get removed every time i restart autocad.
Does somebody knows what to do about this problem?
Alfred.NESWADBA
A loaded DVB is like a loaded file in an appllication. If you close MS-Excel the loaded XLS-file is closed (and will not be opened automatically when you restart MS-Excel) ... same for AutoCAD and DVB.
You can use command _APPLOAD ==> Startup Suite Content ... to make your DVB automatically loaded.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I tried to use appload, so my program loads when autocad starts up,
But no succes, When i restart the AutoCAD i need to do the appload again.
Its like my autocad used a resetpoint every time i restart my AutoCAD.
So what can i do about it ?
Thanks.
norman.yuan
Have you tries as Alfred said?
When _APPLOAD command brings up the dialog box, you look at the frame "Startup Suite" and click "Contents..." button, and add your *.dvb file to the list of applications, which will be loaded automatically into AutoCAD on its startup.
Norman Yuan
Drive CAD With Code
