VBA Object data update - Answer
Hello all,
This is just a quick post for those out there wanting to update data in existing ODTables under VB/A control. Just looking to save others the many hours of trolling cryptic autodesk documentation on the subject and lots of other frustrated blog/web entries.
Tom
Existing Conditions:
dwg with object data attached to entities. In my case I have a table called "Parcels" with a date field attached to closed lwpolylines
vba code that can attach Object data to entities is already working so we're 90% there
Need to:
Replace the contents of an existing field with updated data
Process:
In the UserForm Activate section I have a code block that determined what version was running as I had to support multiple versions over the years so set a global variable to reference. One still had to select the correct version dependent reference objects for things to work
'Which version of acad is running?
Select Case AutoCAD.Application.Version
Case "16.0"
intVersion = 2004
strMapObject = "AutoCADMap.Application.2"
Case "16.1"
intVersion = 2005
strMapObject = "AutoCADMap.Application.3"
Case "16.2s (LMS Tech)"
intVersion = 2006
strMapObject = "AutoCADMap.Application.4"
Case "17.0s (LMS Tech)"
intVersion = 2007
strMapObject = "AutoCADMap.Application.5"
Case "17.1s (LMS Tech)"
intVersion = 2008
strMapObject = "AutoCADMap.Application"
Case "17.2s (LMS Tech)"
intVersion = 2009
End Select
Private Sub UpdateDate
Dim objLayer As AcadLayer
Dim SSet As AcadSelectionSet
Dim fTyp(1) As Integer
Dim Fval(1) As Variant
Dim objText As AcadText
Dim acEnt As Object
Dim objText2 As AcadText
Dim intWork As Integer
Dim strText As String
Dim IP(0 To 2) As Double
Dim height As Double
Dim objDate As Date
Dim amap As AcadMap
Dim ODrcs As ODRecords
Dim ODrc As ODRecord
Dim bolVal, bol2 As Boolean
Dim ent As AcadLWPolyline
Set amap = ThisDrawing.Application.GetInterfaceObject(strMapObject) 'Get the version of code dependent on version running
Set ODrcs = amap.Projects(ThisDrawing).ODTables("Parcels").GetODRecords
On Error Resume Next
ZoomExtents 'Selection seems to be a touch flaky for objects outside the visible extent
frmProcParcels.Hide 'Hide the form during processing
'Turn on the GIS1 layer & make sure layer is selectable
Set objLayer = ThisDrawing.Layers.item("GIS1")
If objLayer Is Nothing Then
Set objLayer = ThisDrawing.Layers.Add("GIS1")
objLayer.color = 72
objLayer.Freeze = False
objLayer.Lock = False
objLayer.LayerOn = True
'Create the Selection Sets
Set SSet3 = ThisDrawing.SelectionSets.Add("GIS")
If SSet3 Is Nothing Then
Set SSet3 = ThisDrawing.SelectionSets.item("GIS")
SSet3.Clear
'Get 2D polylines from GIS1 layer
fTyp(0) = 8: Fval(0) = "gis1" '8 = Layer Name String
fTyp(1) = 0: Fval(1) = "lwpolyline" '0 = Object Type String
SSet3.Select acSelectionSetAll, , , fTyp, Fval
'Correct the odrecord date and dwg
If SSet3.Count > 0 Then 'Only process if there's data to work with
For Each ent In SSet3 'Iterate through each object
bolVal = ODrcs.Init(ent, True, True) 'Get to the ObjectData Records
Set ODrc = ODrcs.Record 'Get Specific Record
ODrc.item(5).Value = Trim(CStr(Date)) 'Update Date field - Remember that the field array is 0 referenced so I'm actually updating the 6th OD Item in my list
ODrc.item(6).Value = Trim(ThisDrawing.Name) 'Store the dwg name for reference after data exported - Updating field 7 if looking at the dialog
bol2 = ODrcs.Update(ODrc) 'Trigger the update
Next
'Clean up prior to exit
frmProcParcels.Show
SSet3.Clear
SSet3.Delete
End Sub
