VBA max user limitation
I have a problem that 20 users can use a .dvb file on my server. But when the 21st user tries to use it they get a Problem in loading dvb file.
Has anybody else come across this problem?
Is this a VBA limitation that is documented somewhere?
Has anybody a solution?
Cheers
David
it's documented in many posts to this ng. don't know if elsewhere
you may want to use google to review how others handled it, basically i
think the solution was keeping the server version as a 'master' and making
local copies as 'working versions' on each machine
depends on how much you're still editing whether that might work but the
google may show other ways...
"davidraft" wrote in message
news:f198c87.-1@WebX.maYIadrTaRb...
> Cheers
> David
I ended up using local option as well.
I check whether a local version is available , if not copy from the
server to the local dir, then run it from local. Updates I handle via
other methods. This has worked well.
> > Cheers
> > David
Nauman M
CAD Bazaar
Same here - we use a .bat (batch) file in user's start up that automatically
copies the server dvb locally. works great, no problems.
Kevin
"Nauman M" wrote in message
news:3FA6C0DA.BC69BDC5@CadBazaarNoSPAM.com...
making
when
> > > Cheers
> > > David
> Nauman M
> CAD Bazaar
