VBA Macro to loop through folder and sub folder to check .dxf file
subhashmecha
subhashmecha
   I need help with VBA Macro. I made program to replace title block from the template(.dxf)file to the files(.dxf) in given folder. I can able to replaces the title block in files(.dxf) in given folder but not in the subfolder.
How to read files to subfolders in given folder. I have attached my Macro with this post.
Thank you in Advance.
Thank you,
Subhash.
norman.yuan
Firstly, there is no need to use Windows Scripting component in your VBA code. You should use VBA built-in function Dir() to loop through files/folders. Using extra component that is not VBA built-in, you added unnecessary dependency to your code, and Windows Scripting component may not be enabled if the computer is in a tightly regulated corporate network.
Since you need to go through all subfolders of a given folder, you need to RECURSIVELY call Dir() to find all subfolders underneath. If you google DIR() and "recursive" you would get a lots of links.
Here I put together some quick code to demonstrate how to dig how subfolders recursively and return a string array with full path of all subfolders. Once you get all the full paths of all subfolders, you can then loop through the subfolder path array to search files in each folder:
Option Explicit
Public Sub Test()
    Dim root As String
    root = "c:\Temp\TestFolder"
    Dim paths() As String
    ReDim paths(0)
    paths(0) = root
''Find all subnfolders' full paths and saved in an array of string GetFolders root, paths
''Show all subfolders' path Dim folder As Variant For Each folder In paths Debug.Print folder Next End Sub Private Sub GetFolders(rootFolder As String, paths As Variant) Dim i As Integer Dim folder As String Dim folders As Collection Set folders = New Collection Dim root As String root = rootFolder & "\" folder = Dir(root, vbDirectory) Do While (folder <> "") If folder <> "." And folder <> ".." Then If (GetAttr(root & folder) And vbDirectory) = vbDirectory Then i = UBound(paths) + 1 ReDim Preserve paths(i) paths(i) = root & folder folders.Add root & folder End If End If folder = Dir Loop Dim fd As Variant If folders.Count > 0 Then For Each fd In folders
''Call the function itself recursively GetFolders CStr(fd), paths Next End If End Sub
HTH
Norman Yuan
Drive CAD With Code
