VBA launch via menu button
Message 1 of 19
Can anyone tell me why I would get the command line error, "Macro not found" when I run the following macro in a button;
^C^C-vbarun "V:/VBA/excel_launch.dvb"
The macro "excel_launch.dvb" is in the correct directory, so I am at a loss.
Replies (18)
Message 2 of 19
You are trying to run a DVB not a macro. Have a look in the help file for the correct useage of vbaload & vbarun.
Regards - Nathan
Message 3 of 19
You are only calling your program, not its internal macro. You need to
nominate that as well.
^C^C-vbarun "V:/VBA/excel_launch.dvb!MyMacro"
Search back through this NG, there are dozens of posts on this subject.
Regards
Laurie Comerford
www.cadapps.com.au
wrote in message news:[email protected]...
Message 4 of 19
My apologies. I have searched on "VBA launch button" and "VBA custom button" and "VBA from menu button" and I have narrowed it down to this;
^C^C^P(vl-vbarun "c://myfolder//myproject.dvb!mymodule.mymacro")
My problem is, I don't know what should be in the place of "mymodule.mymacro"
This is where my confusion is coming from.
Forgive me; I am new to VBA. Message was edited by: TR Young
Message 5 of 19
"mymodule.mymacro"
What is the name of the module that contains the macro you want to run?
What is the name of the macro?
i.e. this would be called as [module1.stub]
Sub stub()
End Sub
"mymodule.mymacro"
Message 6 of 19
I do not understand that at all.
Sub stub()
End sub
can't go in a button macro.
Message 7 of 19
Not if you don't know it's name, nor are willing
to learn anything about what you're asking.
Sub stub()
End sub
Message 8 of 19
Now I'm really lost. What are you trying to say here?
Message 9 of 19
This is not a macro it's a container for your modules which
are containers for your macros. Figure those out and you'll
have your answer. Open the dvb and find the name of
the macro you want to call, and the name of the module
it's contained in.
Message 10 of 19
Enter "Learning VBA" into a google search box.
There' s more to using VBA macro than just entering a file/folder path in
the command line.
First don't confuse a menu macro with a VBA macro.
Second you need to know how a vba project is structured to get the sub
routine's (macro) name and what arguments need to be passed to it .
Murph
http://mappingitout.blogspot.com/
Message 11 of 19
Murph, Thanks for your reply.
First, I have the VBA written and saved; it is a rather simple VBA that was in a tutorial that I found on this site. I am simply trying to understand how to call the VBA program now by assigning the proper text into a custom button's command line.
Second, in looking at my VBA code, where can I find the sub routine's name? (If I could just learn these 2 things, I can really take off; I am pretty good at learning things and being able to piece things together to get what I need) Here is the code;
Option Explicit
Private Sub CommandButton1_Click()
Dim excelapp As Excel.Application
Dim wbkobj As Workbook
Dim shtobj As Worksheet
On Error Resume Next
excel_launch.Hide
Err.Clear
Set excelapp = GetObject(, "excel.application")
If Err 0 Then
Err.Clear
Set excelapp = CreateObject("excel.application")
If Err 0 Then
MsgBox "Could not start Excel", vbExclamation
End
excelapp.Visible = True
Set wbkobj = excelapp.Workbooks.Add
Set shtobj = excelapp.worsheets(1)
excel_launch.Show
End Sub
Private Sub CommandButton2_Click()
excel_launch.Hide
Err.Clear
If Err 0 Then
Err.Clear
MsgBox "No Excel session running.", vbExclamation
excelapp.Quit
excel_launch.Show
End Sub
Private Sub CommandButton3_Click()
End
End Sub
Private Sub UserForm_Click()
End Sub
Message 12 of 19
The code you have goes with a form (dialog box) You need to design the form
with three command buttons on it and name them to match the code. Example:
CommandButton1 to run the sub CommandButton1_Click. Then I would add a sub
like so
Public Sub Main()
UserForm1.Show;;; Userform1 would be the name of your form
End Sub
Now your macro to show the dialog to allow you to click on a button would
be:
^C^C-vbarun "V:/VBA/excel_launch.dvb!Main"
Murph
Option Explicit
excel_launch.Hide
Err.Clear
If Err 0 Then
Err.Clear
If Err 0 Then
End
excel_launch.Show
End Sub
excel_launch.Hide
Err.Clear
If Err 0 Then
Err.Clear
excelapp.Quit
excel_launch.Show
End Sub
End
End Sub
End Sub
Message 13 of 19
I have the form created; that is where I am running into snags. I am understanding how to create forms; every tutorial I have looked at and tried has showed me how to do that. I can't find a tutorial that tells me how to assign a menu button to call up these forms.
Now, for the sub that you are having me add... does it go at the beginning of my code or at the end, or does that not matter? ( I am sure that is a newbie question)
Question about this sub;
Public Sub Main()
End Sub
Do I type this in EXACTLY as you have it shown, or do I leave out "Userform1 would be the name of your form"?
and finally, is the first line of the sub, "Public Sub Main()"
where the callout "main" comes from in the following;
I really appreciate all your help! I am finding everything but what I am looking for when I do my own searches!
Message 14 of 19
You need to create a module then add the code in it.
From the VBA editor top menu "Insert > Module Then type this as it is
replacing Userform1 with the name of your form
Public Sub Main()
UserForm1.Show
End Sub
Yes "MAIN" is where the callout comes from in
Murph
newbie question)
Public Sub Main()
End Sub
Message 15 of 19
A-ha! That did it! everything worked like I wanted it to until I clicked on the 'Quit' button, then I got this error in the command line;
Macro name: "V:/VBA/EXCEL_LAUNCH.dvb!xll" Execution error
Even though I got the error, everything worked like I wanted it to. Any ideas about the error?
And Murph, thanks for the time you are spending with me on this!
Message 16 of 19
Taking a guess but if your Quit button is commandbutton3
you need to change this
End
End Sub
to
userform1.hide
End Sub
Murph
Message 17 of 19
That sealed it. Thank you, Murph!
Message 18 of 19
"Murph" wrote in message
End
End Sub
to
userform1.hide
End Sub
actually if that were the button to quit the application (i didn't see the
beginning of this thread)
you might prefer
Unload Me
End Sub
userform1.hide is like a temporary state where the form is hidden(but still
loaded and running) and presumably brought back to view later in prog with
userform1.show
Unload will close the form and perform any required cleanup provided for in
the Terminate event of the form
Message 19 of 19
There is a further difference between:
me.hide and
unload me
In the first case when the form is called again with .show the Activate code
is run whereas if the form was uloaded, both the initialize and activate
code is run.
Regards
Laurie Comerford
www.cadapps.com.au
"MP" wrote in message
End
End Sub
to
userform1.hide
End Sub
you might prefer
Unload Me
End Sub
userform1.show
