VBA for Computing Total Length, Area, Volume, Count for every Layers
Message 1 of 18
Good Day, I would like to request a codes or an accessible files of autocad vba (userform/macro/.dvb/.frm). What I am trying to achieve is a toolbar that allows me to compute values and arrange it in a table per layers. Any files could do, related or not, finished or not, i'll try to get some  ideas/codes/formats how its made, still learning some codes. As for example..
I draw many lines,polylines, area/region, volume on autocad with different LAYER name each.
then i'll just drag select all the objects I want to compute, then give me result of the TOTAL LENGTH, TOTAL AREA, TOTAL VOLUME, TOTAL COUNT(separated function) showed in TABLE/listbox per LAYER, then later on i'll try to send it to EXCEL.
I hope you guys could spare some files that is accessible. I'll just try to understand the codes.
thanks
Replies (17)
Message 2 of 18
grobnik
Hi @Anonymous
Here below a sample code.
It consist off:
Selecting for each layer the object type and retrive properties, perimeter, area, length.
It's a preliminary, perhaps someone could improve better.
Should be included the table update in the drawing, and in case excel connection.
Bye
Sub Layers_DATA()
Dim LayName() As Variant
Dim ObjectsName() As Variant
Dim LayerSx As AcadLayers
Dim LayerX As AcadLayer
Dim MyObject As AcadEntity
Set LayerSx = ThisDrawing.Layers
Count = 1
Count1 = 1
For Each LayerX In LayerSx
    If LayerX.Name <> "0" And LayerX.Name <> "Defpoints" Then
        ReDim Preserve LayName(Count)
        LayName(Count) = LayerX.Name
        Count = Count + 1
        For Each MyObject In ThisDrawing.ModelSpace
            If MyObject.Layer = LayerX.Name Then
                ReDim Preserve ObjectsName(Count1)
                ObjectsName(Count1) = MyObject.ObjectName
                Select Case ObjectsName(Count1)
                    Case "AcDbPolyline"
                        TotalLength = TotalLength + MyObject.Length
                    Case "AcDbLine"
                    Case "AcDbRegion"
                        TotalPerimeter = TotalPerimeter + MyObject.Perimeter
                        TotalArea = TotalArea + MyObject.Area
                    Case "AcDbCircle"
                        TotalCirc = TotalCirc + MyObject.Circumference
                        TotalDiam = TotalDiam + MyObject.Diameter
                    Case "AcDb3dSolid"
                        Debug.Print "PIPO"
                End Select
                Count1 = Count1 + 1
        Next
    'TRANSFER DATA TO EXCEL or to a TABLE and reset data and count for next layer
    TotalLength = 0
    TotalPerimeter = 0
    TotalArea = 0
    TotalCirc = 0
    TotalDiam = 0
    Count1 = 0
Next
End Sub
Message 3 of 18
@grobnik
Thanks sir,  Finally I got progress adding the length of objects.
However, it seems it sums up all the lines in drawings regardless of layers.
How can I separate the results per layers, and use selection instead of automatically adds all objects in drawing.
And to show the result in listbox.
I hope someone could give me a little ideas that I could put in puzzle.
Thanks again sir.
Message 4 of 18
grobnik
Hi @Anonymous ,
the code made calculation for each layer, because inside the for next cycle that switch layer.
Before the part of code:
    TotalLength = 0
    TotalPerimeter = 0
    TotalArea = 0
    TotalCirc = 0
    TotalDiam = 0
    Count1 = 0
Next
you already have the possibility to transfer data about:
Layers
Count of object per layer
Length
Area
etc
When all global count will be settle to 0 in the code, means that we are analyzing objects in the next one layer:
See part of code below.
Set LayerSx = ThisDrawing.Layers ' collect all layers in the dwg
Count = 1
Count1 = 1
For Each LayerX In LayerSx ' cycle for each layer into dwg.
    If LayerX.Name <> "0" And LayerX.Name <> "Defpoints" Then 'do not consider special layer including layer 0.
I suggest to transfer data to a Table inside the dwg, or directly to excel.
A listbox or combobox it's more complex, due to you have create a form, and so on.
This part shall be still developed, until now, and it's not completely solved, my focus was retrive data from objects.
I still have some issue with 3d Objects for volume.
I'll keep you updated.
Bye
Message 5 of 18
grobnik
Hi @Anonymous I made some progress, see attached dwg and code.
The procedure creates 4 different tables inside drawing Linear, Area, Volume (I'm still working on), and count of object.
The code should be more or less linear and flexible, the main issue it's to match the object properties with the correct amount. For Example there is a circle object which I considered circumference as Linear data, so added to linear table, and area to Area Table, may be wrong or correct I don't know.
In addition I excluded from count layer 0, Defpoints and AM_CL the last on  related to Construction Line.
If you need you can add or remove more, adding / removing it directly on drawing,
You should check and a give me a feedback.
As you can see from the code the total amount it's made for each layer, the same as before.
Once you run the procedure a group of table will be drawn, so if you made modifications to procedure, before running it again remember to delete the table group placed above yours old one. On the opposite you will have tables overlapped.
If you want to check attached the code (ZIP FIle of .BAS procedure for VBA) and dwg (saved Autocad 2018)
Bye.
Sub Layers_DATA()
LayCount = LayerSx.Count
Dim ptMyTableLinear(0 To 2) As Double
ptMyTableLinear(0) = 3100
ptMyTableLinear(1) = 22000
ptMyTableLinear(2) = 0
Dim ptMyTableArea(0 To 2) As Double
ptMyTableArea(0) = 3100 * 2
ptMyTableArea(1) = 22000
ptMyTableArea(2) = 0
Dim ptMyTableVolume(0 To 2) As Double
ptMyTableVolume(0) = 3100 * 3
ptMyTableVolume(1) = 22000
ptMyTableVolume(2) = 0
Dim ptMyTableTotObj(0 To 2) As Double
ptMyTableTotObj(0) = 3100 * 4
ptMyTableTotObj(1) = 22000
ptMyTableTotObj(2) = 0
Dim MyTableLinear As AcadTable
Dim MyTableArea As AcadTable
Dim MyTableVolume As AcadTable
Dim MyTableTotObj As AcadTable
Dim MyModelSpace As AcadModelSpace
Set MyModelSpace = ThisDrawing.ModelSpace
'AddTable(InsertionPoint, NumRows, NumColumns, RowHeight, ColWidth)
Set MyTableLinear = MyModelSpace.AddTable(ptMyTableLinear, LayCount, 2, 300, 1550)
Set MyTableArea = MyModelSpace.AddTable(ptMyTableArea, LayCount, 2, 300, 1550)
Set MyTableVolume = MyModelSpace.AddTable(ptMyTableVolume, LayCount, 2, 300, 1550)
Set MyTableTotObj = MyModelSpace.AddTable(ptMyTableTotObj, LayCount, 2, 300, 1550)
'object.SetCellValue row, col, val
MyTableLinear.SetCellValue 0, 0, "LINEAR"
MyTableLinear.SetCellValue 1, 0, "LAYERS"
MyTableLinear.SetCellValue 1, 1, "VALUE"
MyTableArea.SetCellValue 0, 0, "AREA"
MyTableArea.SetCellValue 1, 0, "LAYERS"
MyTableArea.SetCellValue 1, 1, "VALUE"
MyTableVolume.SetCellValue 0, 0, "VOLUME"
MyTableVolume.SetCellValue 1, 0, "LAYERS"
MyTableVolume.SetCellValue 1, 1, "VALUE"
MyTableTotObj.SetCellValue 0, 0, "TOT. OBJ."
MyTableTotObj.SetCellValue 1, 0, "LAYERS"
MyTableTotObj.SetCellValue 1, 1, "VALUE"
Row = 2
  If LayerX.Name <> "0" And LayerX.Name <> "Defpoints" And LayerX.Name <> "AM_CL" Then
        MyTableLinear.SetCellValue Row, 0, LayerX.Name
        MyTableArea.SetCellValue Row, 0, LayerX.Name
        MyTableVolume.SetCellValue Row, 0, LayerX.Name
        MyTableTotObj.SetCellValue Row, 0, LayerX.Name
        Row = Row + 1
Next
Count = 1
Count1 = 1
        Count = Count + 1
                    Case "AcDbPolyline"
                        If MyObject.Closed = True Then
                            For Row = 2 To LayCount
                                If MyTableArea.GetCellValue(Row, 0) = LayerX.Name Then
                                    MyTableArea.SetCellValue Row, 1, FormatNumber(TotalArea, 2)
                            Next Row
                                If MyTableLinear.GetCellValue(Row, 0) = LayerX.Name Then
                                    MyTableLinear.SetCellValue Row, 1, FormatNumber(TotalLength, 2)
                            Next Row
                    Case "AcDbLine"
                        Next Row
                    Case "AcDbRegion"
                        TotalLength = TotalLength + MyObject.Perimeter
                        Next Row
                        Next Row
                    Case "AcDbCircle"
                        TotalLength = TotalLength + MyObject.Circumference
                        Next Row
                        Next Row
                    Case "AcDb3dSolid"
                        Debug.Print "PIPO"
                End Select
                    If MyTableTotObj.GetCellValue(Row, 0) = LayerX.Name Then
                        MyTableTotObj.SetCellValue Row, 1, FormatNumber(Count1, 2)
                Next Row
                Count1 = Count1 + 1
        Next
    TotalLength = 0
    TotalArea = 0
    Count1 = 0
    Row = 2
Next
End Sub
Message 6 of 18
grobnik
I appreciate the effort sir, the cad file seems broken, it gives me an error "Drawing file is not valid." while I can still open my other files. BTW, i'm using 2021.
I tried to copy and paste the vba codes, some variables not defined, but I added it now
Dim row As Integer
Dim count As Integer
Dim count1 As Integer
Dim TotalArea As Long
Dim TotalLength As Long
it works now,
AREA is perfect
LINEAR is perfect (except it also calculates the edge length of a REGION)<< I get region from exploding 3D/cube
COUNT seems not accurate doesn't count 1 RECTANGLE as an object (if possible, can it count the objects with same shape/object, for example
           Layer1=3 (lines with same length)
           Layer1=2 (rectangle same size)
           Layer2=5 (circle same size)
and how can I increase the TEXT height of table, the table size is fine, since I use mm units
Again, thank you for the effort sir.
God Bless
Message 7 of 18
grobnik
Hi @Anonymous ,
I appreciate you tested so in deep, variable could be not declared if you do not insert an Option Explicit inside the code, and on my side there isn't this option, in any case are secondary variable used just in for next loop or for counting.
Concerning the text height you can define by "STYLE" the style of text you want to apply to your global dwg for example "standard", and in the same way it will be applied to Table, as alternative you can set the text height for each cell.
I'll check during the week if I'll have time, and give you a feedback for count.
Message 8 of 18
Tom.LynchKGXNK
Wow this is really impressive!
Is there a way you can dump the information straight into excel?
Message 9 of 18
grobnik
@Tom.LynchKGXNK
Yes, share a sample dwg with info required to be passed to excel and i'll show you the code.
Message 10 of 18
Tom.LynchKGXNK
Hi Grobnik
Thanks heaps for your help, I've spent so much time trying to figure this out.
Like the VBA above, I'm trying to output total length of lines, polylines, number of lines, number of polylines, number of blocks, and hatch areas for each layer in the drawing as a csv file.
Do you think something like that is possible?
I attached a .dwg that i am currently working on.
Thanks heaps for your help!!
Message 11 of 18
grobnik
Hi @Tom.LynchKGXNK I had a look to your dwg, it's very complex, I can give you some methods for counting mains objects like line polylines blocks, but I guess you have to give me some "filters" for example: If I'll search for blocks perhaps could be counted the referenced blocks but not part of drawing, just to explain better drawing not purged of unused objects.
So if you have a filter for example certain layers, or block name, or line / polyline colours shall be more easy to extract only wanted data.
In the mean time I'll work on it, try to use the code in this post, if you are able to use VBA, just to start evaluating later could be refined.
Bye
Message 12 of 18
grobnik
Hi @Tom.LynchKGXNK here attached the result of shared drawing as table inside the drawing.
Will follow excel transfer instead table into the drawing.
Please look at results and let me know if is covering what you are expecting.
Bye
Message 13 of 18
Tom.LynchKGXNK
Hi @grobnik
That is perfect mate! Exactly what I was trying to do.
I wasn't going to worry about filtering blocks, I was thinking if I can get it to work, I will just assign each block type its own layer and sort it out in excel.
Thanks, heaps, for your help so far!
Message 14 of 18
grobnik
@Tom.LynchKGXNK
actually LAYER "0" will be not taken in consideration, it's still used ? shall be considered into the procedure ?
Let me know
Message 15 of 18
Tom.LynchKGXNK
Hi @grobnik,
I don't need layer "0" but if it's easier to keep it in I'm happy for it to stay.
Thanks again!
Tom
Message 16 of 18
grobnik
@Tom.LynchKGXNK
Here attached a limited code just for your example, and below the excel results.
You have as first step add Excel reference to VBA project.
Use on Visual basic editor Autocad Application the menu command tools, and then references, flag the Excel Library.
Showed number after Microsoft Excel XX.X Object Library it's depend from Excel release you have installed in your machine.
There is in addition a small routine that could help you to discover several object types.
I hope you know how to manage the VBA project.
Let me know.
LAYERSPOLYLINES TOTAL LENGHTPOLYLINES TOTAL AREALINES TOTAL LENGHTTOTAL BLOCKS
064,1527,60
ZTitleBlock
batter top1.256,17
bitumen edge
pathway4.621,13398,89
kerb back721,63291,07
kerb lip2.748,11513,14
kerb SM3
stormwater catchpit
stormwater manhole
table drain invert
stormwater headwall
building
XELEC OH
landscape
driveway concrete hatch
surface toe
stormwater pipe
stormwater pit
stormwater culvert
fence line
fence gate
electricity pillar
driveway
creek bank toe
subsoil rd
saw cut bdy
earthwork drain invert
earthwork drain edge
edge of verge
bridge abutment
bridge deck
retaining wall top
stormwater gully unit
RS01 DESIGN
Extra DS
RS05 DESIGN
RS06 DESIGN
stormwater gully unit setout
BREAKLINE
KR19 DESIGN
parks garden edge
build line
electricity pole text
MF33 DESIGN
rock prot
ACO hatch
invert drain line
mowing strip
TERRACE HATCH
RST01 DESIGN
Culvert RS01 14 558
Culvert RS01 14 558 IO
Message 17 of 18
Tom.LynchKGXNK
Hi @grobnik
This is really impressive, this is exactly what I have been trying to do!
Thanks heaps for setting this up!!!
Cheers
Tom
Message 18 of 18
grobnik
Thank you, it's just a starting point, you can add what do you need to count, or summarize or something else.
Scope of project is give you a tools and the path for extracting data from your dwg. I don0t know in deep your requirements.
Let me know if you need more support.
Bye
