VBA Explode vs AutoCAD Command Explode
Hello - Here is my situation: I have a block in AutoCAD that is made up of
other blocks that all have XData. If I explode the parent block from a VBA
program, all of the resulting children blocks are missing their XData. If I
explode the parent block using Explode from the command line, the resulting
children retain their XData. Is this a bug or is there a way of retaining
XData after an explode from a VBA program?
Thanks in advance.
VBA just does it that way, but this one works the way you want it:
Use the ExplodeEx routine from VBDesign at:
http://vbdesign.hypermart.net/cadpages/code.htm
