VBA code Running too fast, How do I slow it down?
I basically have Autocad extracting attributes to a text file on our server, the have some VBA code opening Excel, formatting the data, and copy/pasting it into another Excel doc. The problem is, that the time it takes Autocad to the server (about a sec or two) the code it al ready trying to access the new text file before it is finished writing. Any ideas of how I could delay the app from moving on? Thanks again for any assistance. You all are very wonderful people for your support. I have learned a lot from this group, and I have been writing VB now for only a few days.
Something like this, with a 5 or 10 second pause? I'm not familiar with attribute extraction, but I'm surprised it doesn't finish writing the file. Are you using SendCommand in your subroutine? -- James Public Sub PausePreview() Dim i As Long, pauseTime As Double, start As Double pauseTime = 5 'seconds ThisDrawing.SendCommand ("preview" & vbCr) If Timer + pauseTime < (24 * 60 * 60) Then start = Timer Do Loop Until Timer > start + pauseTime Else 'loop would have run for 24 hours before exiting... 'could enhance to loop until either: ' A) (time > endTime), or ' B) (date >= endDate) and (time > endTime) End If SendKeys "{ENTER}" End Sub
Dan wrote: > Any ideas of how I could delay the app from moving on? Sounds like you need to restructure the app. At some point, you're surrendering flow control to an external process. Excel can be automated from within AutoCAD. That's the approach I'd take. -- "It's beauty that captures your attention; personality which captures your heart."
I am using the send command to call up a lisp, I need to figure out how to just convert the lisp to VBA. I am very new at this, so I appreciate any help. Thanks! [VBA code] Private Sub CommandButton7_Click() ThisDrawing.SendCommand "wallxport" & vbCr Dim thisdwgpath As String thisdwgpath = ThisDrawing.GetVariable("dwgprefix") Dim excelApp As Excel.Application Dim wbkObj As Workbook Dim shtObj As Worksheet On Error Resume Next UserForm1.Hide Err.Clear Set excelApp = GetObject(, "Excel.Application") If Err <> 0 Then Err.Clear Set excelApp = CreateObject("Excel.Application") If Err <> 0 Then MsgBox "Could not start Excel.", vbExclamation End End If End If 'Clear Clipboard Dim oDataObject As DataObject Set oDataObject = New DataObject oDataObject.SetText "" oDataObject.PutInClipboard Set oDataObject = Nothing 'End Clear Clipboard AppActivate ThisDrawing.Application.Caption excelApp.Visible = True 'verify file location If Dir$(thisdwgpath & "\data\wallxport.txt") = " " Then MsgBox "The file was not found. Please try again!" End If 'verify file location end Workbooks.OpenText FileName:= _ (thisdwgpath & "\data\wallxport.txt"), Origin:=437 _ , StartRow:=1, DataType:=xlDelimited, TextQualifier:=xlSingleQuote, _ ConsecutiveDelimiter:=False, Tab:=True, Semicolon:=False, Comma:=True, _ Space:=False, Other:=False, FieldInfo:=Array(Array(1, 1), Array(2, 1), Array( _ 3, 1), Array(4, 1), Array(5, 1), Array(6, 1), Array(7, 1), Array(8, 1), Array(9, 1), Array(10 _ , 1)), TrailingMinusNumbers:=True Cells.Select With Selection .HorizontalAlignment = xlCenter .VerticalAlignment = xlBottom .WrapText = False .Orientation = 0 .AddIndent = False .IndentLevel = 0 .ShrinkToFit = False .ReadingOrder = xlContext .MergeCells = False End With Selection.Sort Key1:=Range("A1"), Order1:=xlAscending, Header:=xlGuess, _ OrderCustom:=1, MatchCase:=False, Orientation:=xlTopToBottom, _ DataOption1:=xlSortNormal Range("A1:J250").Select Selection.Cut Workbooks.Open FileName:= _ (thisdwgpath & "data\Quantities.xls"), Origin _ :=xlWindows Sheets("Walls").Select Range("B3").Select ActiveSheet.Paste Range("A1").Select Range("A4:A5").Select Range("A5").Activate Selection.AutoFill Destination:=Range("A3:A5"), Type:=xlFillDefault Range("A3:A5").Select Range("A1").Select ActiveWorkbook.Close SaveChanges:=True ActiveWorkbook.Close SaveChanges:=False excelApp.Quit End Sub [Wallxport.lsp] (defun c:WALLXPORT () (command "filedia" "0") (setq EXPORTFILE (strcat (getvar "dwgprefix")"data\\WALLXPORT")) (command "-attext" "cdf" "walltemplate" EXPORTFILE /013) (command "filedia" "1") (princ) ) "James Belshan" wrote in message news:40eef98a$1_2@newsprd01... > Something like this, with a 5 or 10 second pause? > > I'm not familiar with attribute extraction, but I'm surprised it doesn't > finish writing the file. Are you using SendCommand in your subroutine? > > -- James > > > Public Sub PausePreview() > > Dim i As Long, pauseTime As Double, start As Double > pauseTime = 5 'seconds > > ThisDrawing.SendCommand ("preview" & vbCr) > > If Timer + pauseTime < (24 * 60 * 60) Then > start = Timer > Do > Loop Until Timer > start + pauseTime > Else > 'loop would have run for 24 hours before exiting... > 'could enhance to loop until either: > ' A) (time > endTime), or > ' B) (date >= endDate) and (time > endTime) > End If > > SendKeys "{ENTER}" > > End Sub > > > >
"Frank Oquendo" wrote in message news:40ef0263$1_1@newsprd01... > Dan wrote: > > Any ideas of how I could delay the app from moving on? > > Sounds like you need to restructure the app. Yup! Guess so, I got this far, but its just a beginning, thanks. > > At some point, you're surrendering flow control to an external process. > > Excel can be automated from within AutoCAD. > > That's the approach I'd take. > > -- > "It's beauty that captures your attention; personality which captures > your heart." > >
Here's another (nearly identical) time-wasting routine. Of course, the cool thing to do would be to write the attributes directly to your target Excel worksheet. ' wait a given number of seconds Public Sub Wait(sngWaitTime As Single) Dim sngEndTime As Single Debug.Print "Start Time: " & CStr(Timer()) sngEndTime = Timer() + sngWaitTime ' if interval doesn't span system date rollover If Not Timer() > sngEndTime Then Do While Timer() < sngEndTime ' just waste time Loop End If Debug.Print "End Time: " & CStr(Timer()) End Sub -- John Goodfellow irtfnm use john at goodfellowassoc dot com "Dan" wrote in message news:40eec556$1_3@newsprd01... > I basically have Autocad extracting attributes to a text file on our server, > the have some VBA code opening Excel, formatting the data, and copy/pasting > it into another Excel doc. The problem is, that the time it takes Autocad > to the server (about a sec or two) the code it al ready trying to access the > new text file before it is finished writing. Any ideas of how I could delay > the app from moving on? > > Thanks again for any assistance. You all are very wonderful people for your > support. I have learned a lot from this group, and I have been writing VB > now for only a few days. > >
Try adding: do events -- David Wishengrad President & CTO MillLister, Inc. Software for BOM, measuring, stretching and controlling visibility of multiple 3D solids. Http://Construction3D.com
