VBA app to run across currently opened dwgs
mdhutchinson
Advisor Advisor
mdhutchinson
I am new to VBA but have done lots of Visual lisp.
Is is possible to write a VBA application that will run across currently opened drawings? Could someone refer me to an example I might get me started?
from help file:
Sub Example_Documents()
' This example obtains a reference to the Documents collection
' and displays information about the loaded documents.
Dim Document As AcadDocument
Dim msg As String
msg = vbCrLf
' Cycle through the Documents collection and retrieve the names
' of the loaded documents
For Each Document In Documents
msg = msg & Document.name & vbCrLf
Next
' Display loaded document information
If Documents.count > 0 Then
MsgBox "The loaded documents are: " & msg
Else
MsgBox "There are no loaded documents!"
End Sub
