VBA and Languages (English, German, etc)
Is VBA code written for the English version of Autocad compatible with
German and other versions of Autocad. Or would it have to be translated for
each language.
Thank you,
JC
Joe,
It's the same language, but here are a couple of things to watch out for;
SendCommand:
If you are using it to call any AutoCAD command, make sure you use the
underscore in front of the command name, "_Zoom", so that it uses the
untranslated command name.
Numeric Formatting:
In some countries, such as Germany, they use a comma as the decimal
character in number. You can see this by going to Windows Control Panel and
looking at the regional settings. AutoCAD is hard coded to ignore the
regional settings for numbers and stick with the decimal point.
The problem is that VBA still uses the regional settings. Try setting your
region to German(Germany), then set a breakpoint in your macro the first
place where you are dealing with doubles. You will see that VBA is using the
comma but AutoCAD uses the decimal point. You will hit all kinds of errors
in this situation. The only fix I know of is for your macro to temporarily
change the regional settings while it is running then change it back with
it's done. Perhaps someone else has a better soution. I hate the thought of
changing the system settings like that but I don't know of any other way.
Glen
Thanks for the info. Glen
JC
"Glen Albert" wrote in message
news:B027607DAC3E66EA003B8D91C0C5E25F@in.WebX.maYIadrTaRb...
> Joe,
> SendCommand:
> Numeric Formatting:
and
the
of
> Glen
