VB "matrix "class usage in VBA
I need to invert an UCS matrix, so i've find
a matrix class,
with an Invert method
 I use staright VBA under Autocad, and i don't know
how to use this ressource :
on this page:
http://msdn2.microsoft.com/en-us/library/system.drawing.drawing2d.matrix.aspx
I find information on declaration, usage, syntax, but where is the code
? where is the matrix class module ?
Le site de G-EAUX et de PowerClic: http://www.g-eaux.com
Le newsgroup historique et indépendant d'Autocad
news://news.planetar.net/autocad.general
What you posted is only for .NET development, not VBA.
If you need to invert a matrix, you can use excel as "service" for this
task.
-gnb
"gégématic <-remove-it-gegematic@g-eaux.com>"
<=?UTF-8?Q?g=C3=A9g=C3=A9matic_<-remove-it-gegematic@g-eaux.com>?=> wrote in
message news:5409102@discussion.autodesk.com...
I need to invert an UCS matrix, so i've find a matrix class, with an Invert
method
http://msdn2.microsoft.com/en-us/library/system.drawing.drawing2d.matrix.invert.aspx
I use staright VBA under Autocad, and i don't know how to use this
ressource :
on this page:
I find information on declaration, usage, syntax, but where is the code ?
But it gives a syntax for VBA ?
Mayble the drawing.dll is a .net application, but it seems that i can
use it with vba ?
> task.
I don't use excel ...
It gives VB syntax that relies on the .NET framework. VBA can not use the .NET framework.
Regards - Nathan
> Regards - Nathan
Ok, no w i understand.
Gérald
