VB or VBA
VB or VBA
VB or VBA
My company has VB6 Enterprise Edition. Is their an advantage to using VBA?
Are there things that VBA can do that VB6 can't?
Also, can someone explain how to get a toolbar button to run a .DLL file
instead of an .EXE file?
I am new to interfacing with AutoCAD. My experience is with VB and .EXE
files
VB beats the tar out of VBA. When it comes to accessing AutoCAD events,
methods and properties, the two are identical in every respect save one: VBA
has a ThisDrawing object which triggers events from every drawing. VB does
not have this nor an automatic way to synchronize documents when the user
flips from one drawing to another. When it comes to available tools VB is
the winner, hands down.
As for getting your toolbars to run VB created apps: if the app is an exe,
just use startapp. If it's a dll, you can either use VisualLISP or a VBA
project to access your dll.
"badgers" wrote in message
news:85cuok$j816@adesknews2.autodesk.com...
> files
Hi Frank,
I may be wrong, but it is true that STARTAPP will only work with an
installed program ?
Regards
Laurie Comerford
CADApps
Frank Oquendo wrote in message
news:85cv41$jj16@adesknews2.autodesk.com...
VBA
VBA?
> > files
how does one call a DLL from AutoLisp?
Thank you all for your time and have a great day
To load an ActiveX dll from Visual LISP use:
(setq DllObj (vla-getInterfaceObject (vlax-get-acad-object)
"DllName.DllClass"))
Hope this helps.
Andrew Wilford
visualdcl@mindspring.com
Visual DCL v1.0
http://www.mindspring.com/~cwilford/visualdcl.htm
------------Millennium special $89.95!-----------
STARTAPP will fire up any exe it can find. Now accessing ActiveX objects
from those exes is another thing altogether.
Laurie Comerford wrote in message
news:85dcsb$2e414@adesknews2.autodesk.com...
> Hi Frank,
> installed program ?
> Regards
> Laurie Comerford
> CADApps
> VBA
does
user
is
exe,
> VBA?
file
.EXE
> > > files
