[VB.NET] Disable SAVE Dialog ?
I have a VB.NET application that I'm writing, and I want to disable the saveas dialog.
Simply I can set FILEDIA to 0, but then all dialogs with files are not shown. So i need e.d. when saveas is chosen disable this and after saving, enable it.
But on my beginCommand it's too late to disable filedia, because this is then fired after the saveas result.
Is there another way to do this in VB.NET?
Have you thought about redefining the Saveas
command to use yours instead?
Ed
saveas dialog.
Are you trying not get the saveas prompt when
closing docs via VB/VBA?
or am I missing this comletely?
Andy
saveas dialog.
Well, I tried this (see below), it's in the EndOpen event, since the drawings are opened thru my app. But, Only the UNDEFINE sendcommand works, the defun command is ignored. When I type the defun command in ACAD's command line, it works, so it's almost like these commands can't be executed thru my vb app.?
Private Sub myAutoCadApp_EndOpen(ByVal FileName As String) Handles myAutoCadApp.EndOpen
myAutoCadApp.ActiveDocument.SendCommand("UNDEFINE" & vbTab & "SAVEAS" & vbCr)
myAutoCadApp.ActiveDocument.SendCommand("(defun C:SAVEAS () ())" & vbCr)
End Sub
You just don't have your defun doing anything. Try
this.
ThisDrawing.SendCommand("(defun C:Saveas () (princ
""This command has been redefined."")(princ))" & vbCr)
Ed
Well,
"SAVEAS" & vbCr)
() ())" & vbCr)
End Sub
