VB GetPoint Errors (NOT VBA)
Hi.
I am writing the following VB (NOT VBA) Activex DLL to get a Point on the
drawing area, thru a Visual Basic Form, using a Command in Vusal Lisp.
I have a simple form with a one button:
VISUAL BASIC ACTIVEX DLL
Class Code: Class Name: mSlides
Public Sub SlideLib()
Set frmTest = New frmSlides
frmTest.Show vbModal
While caso = 1
BuscarPunto
Wend
Unload frmTest
End Sub
Module CODE:
Sub BuscarPunto()
Dim PUNTO As Variant
MsgBox "Donde lo desea insertar", vbOKOnly
PUNTO = ThisDrawing.Utility.GetPoint(, "Seleccione un Punto")
End Sub
Form CODE:
Private Sub Form_Load()
Set acadApp = GetObject(, "AutoCAD.Application")
Set ThisDrawing = acadApp.ActiveDocument
End Sub
Private Sub Slide_ButtonClk()
caso = 1
Unload Me
End Sub
This is my VisualLisp Program
(defun c:slides ()
(vl-load-com)
(setq acd (vlax-get-acad-object))
(setq srv (vlax-invoke acd "getinterfaceobject" "HRTSLIDELIB.mSlides"))
(setq ret (vlax-invoke srv "slidelib"))
I have several questions:
1. Why do I have to use the Instruction:
in my Code, If I don`t put this instruction the AutoCAD2002 hangs up.
2. Why do I have to use the while in my Code, I have been Unable to write
the Slide_Button Click as follows:
Unload Me
BuscarPunto
End Sub
If I write this code AutoCAD2002, hangs up.
So in resume,
I would like tow write an ActiveX DLL, with a form, and a button , which
lets me pick a point in the drawing area and the return to the form.
Sorry for my English
Caracas-Venezuela
I need help, the program is working but it doesn't look natural.
Hi Tomas,
I will load your code up, try it and see what happens. Until then, or
someone else gives you a better option, try using a vba program to
access the DLL instead of vlisp. I always use a dvb file to access and
run vb dlls.
Mike
Mike Tuersley
PhD @ CADalyst's AutoCAD Clinic
http://www.cadonline.com
Speed_CAD
Hola Tomas...
Como eres de venezuela te contesto en español:
Lo que puedes hacer es en VB declarar dos variables publicas una de tipo varint y otra de tipo Boolean, por ejemplo:
Public vbPunto As Variant
Public vbAceptar As Boolean
Y en el boton del cual deseas obtener el punto la asignas a la variable vbAceptar = True, y desde Visual Lisp verificas el dato de la variable vbAceptar, por ejemplo:
(if (= (vlax-get-property srv 'vbAceptar) :vlax-true)
(progn
(setq punto (getpoint "\nSeleccione punto: "))
...aqui debes volver al formulario de VB...
Entonces los valores de punto se los asignas a vbPunto, pero antes debes crear una variable en Visual Lisp con safearray y asi desde Visual Basic podras leer cada coordenda del punto con vbPunto(0) para X, vbPunto(1) para Y y vbPunto(2) para Z.
Yo lo hago de esa forma, en este momento no tengo a mano el codigo completo pero te dejo la idea para que lo hagas...
Un saludo de SpeeCAD... 🙂
CHILE
FORO: http://www.hispacad.com/foro
Mauricio Jorquera
Umm...SpeedCAD, do you know you're replying to a message that is a year and a half old?
Speed_CAD
Yep... I know it wivory, but this message did not have answer.
excuse me 😞
Mauricio Jorquera
Certainly no need to apologise - I just thought maybe you didn't realise.
