vb block insert
vb block insert
vb block insert
When I insert a block using the following code in paper space the block does not appear. Work fine in model space. Does anyone have any ideas?
' Insert the block
Dim InsertPnt As Variant
Dim prompt1 As String
prompt1 = vbCrLf & "Enter the Insertion point for the Titleblock: "
'user defines insertion point
InsertPnt = ThisDrawing.Utility.GetPoint(, prompt1)
Dim blockRefObj As AcadBlockReference
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(InsertPnt, "K:\Autodesk\AutoCAD\TEMPLATES\Howden_Standard_B.dwg", 1#, 1#, 1#, 0)
ZoomExtents 'Zoom extents on the drawing
I figured out my mistake.
What was the mistake?
I am experiencing the same problem.
Look at the following:
If ThisDrawing.ActiveSpace = acModelSpace Then
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock ....
Else
Set blockRefObj = ThisDrawing.PaperSpace.InsertBlock ....
arcticad
You can also simplify the code.
Set blockRefObj = ThisDrawing.GetSpace.InsertBlock ....
[code]
Function GetSpace() As Variant
If IsModelspace Then
Set GetSpace = ThisDrawing.ModelSpace
Else
Set GetSpace = ThisDrawing.PaperSpace
End Function
Public Function IsModelspace() As Boolean
Dim document As AcadDocument
For Each document In Documents
If document.Active = True Then
If document.ActiveSpace = acPaperSpace Then
IsModelspace = document.MSpace
Exit For
Else
IsModelspace = True
Exit For
Next
End Function
[/code]
(defun botsbuildbots() (botsbuildbots))
