VB-Autocad relationship
I wrote a little app in VB that will insert blocks having specific values from an excel file. Everything works fine if the autocad is idle, but if there is an active command like line command, of course the vb exe will give me a message that Autocad is busy. I have my reasons to run this application outside of Autocad, as a separate exe file. My question is: can I somehow check from the exe file if there is an active command running in Autocad and cancel it (like esc key) and then continue with block placing? Or, if Autocad is busy, can I "convert" this into a message(from VB) and than wait until AutoCad is idle? My feeling is that I cannot do this, but I will appreciate any opinion.
i think there is property checking is acad bussy
Sub Example_IsQuiescent()
Dim State As AcadState
Set State = GetAcadState
If State.IsQuiescent Then
MsgBox "AutoCAD is quiescent."
Else
MsgBox "AutoCAD is not quiescent."
End Sub
just don't know why such a crypitc name "quiscent"
