Using code to modify code in a DVB file : disable the Object Modified Event
I remember reading about this before, but I can't seem to find it.
I need to disable and then reenable the Object Modified Event.
I want some code to change the event in the file so it won't fire when saving the file.
This is to prevent it from running a zillion times when I save a file. As every object is modified on save.
I tried to unload the DVB file with another when save is run. However. When I run "Copy with Base Point".
Save runs in the middle of the command and tried to unload the dvb file. and AutoCAD crashes.
Any Help would be appreciated. Thanks.
(defun botsbuildbots() (botsbuildbots))
