UserForm_initialize again on Unload
When I unload my form, function UserForm_initialize begins to run automatically. There is no specific instruction to make this happen. I would rather it not happen. Does anyone know of a circumstance under which this might happen? When I make a small program and test it out it does not happen, but in my very large project it does. Thanks, -Randy
Hello Randy, For me some times it occurs because, after unload it, I make a call to one or more objects in that user_form (for example, MyVar = User_Form.TextBox1.Text). Could it be what is happening to you? "Randy Richardson" escribió en el mensaje news:40ab7a8a_1@newsprd01... > When I unload my form, function UserForm_initialize begins to run > automatically. There is no specific instruction to make this happen. I > would rather it not happen. Does anyone know of a circumstance under which > this might happen? When I make a small program and test it out it does not > happen, but in my very large project it does. > > Thanks, > > -Randy > >
Thanks for your reply, Luis. No, after I close the form I don't make any more calls to the objects in the form. It just goes to UserForm_initialize right after the call to UserForm.Unload. Fortunately, this does not do any real damage. -Randy "Luis Alberto" wrote in message news:40ac515c$1_1@newsprd01... > Hello Randy, > > For me some times it occurs because, after unload it, I make a call to one > or more objects in that user_form (for example, MyVar = > User_Form.TextBox1.Text). Could it be what is happening to you? > > "Randy Richardson" escribió en el > mensaje news:40ab7a8a_1@newsprd01... > > When I unload my form, function UserForm_initialize begins to run > > automatically. There is no specific instruction to make this happen. I > > would rather it not happen. Does anyone know of a circumstance under > which > > this might happen? When I make a small program and test it out it does > not > > happen, but in my very large project it does. > > > > Thanks, > > > > -Randy > > > > > >
Try using: Unload Me or (if this doesn't help) UserForm_Activate() event instead of UserForm_Initialize() one. Regards, Maksim Sestic www.geoinova.com "Randy Richardson" wrote in message news:40acd152$1_1@newsprd01... > Thanks for your reply, Luis. > > No, after I close the form I don't make any more calls to the objects in the > form. It just goes to UserForm_initialize right after the call to > UserForm.Unload. > > Fortunately, this does not do any real damage. > > -Randy > > "Luis Alberto" wrote in message > news:40ac515c$1_1@newsprd01... > > Hello Randy, > > > > For me some times it occurs because, after unload it, I make a call to one > > or more objects in that user_form (for example, MyVar = > > User_Form.TextBox1.Text). Could it be what is happening to you? > > > > "Randy Richardson" escribió en el > > mensaje news:40ab7a8a_1@newsprd01... > > > When I unload my form, function UserForm_initialize begins to run > > > automatically. There is no specific instruction to make this happen. I > > > would rather it not happen. Does anyone know of a circumstance under > > which > > > this might happen? When I make a small program and test it out it does > > not > > > happen, but in my very large project it does. > > > > > > Thanks, > > > > > > -Randy > > > > > > > > > > > >
