User Form Text & label button
I would like to create a form with a text button and a label button.
The Value of the Label button equal the value of the text button / 456
(eg.).
How do I set (what code?) my label button to be updated after i enter a
value in the text button?
kh
Hi Schuyl,
try this:
get a user form with label1 and textbox1 and commandbutton1
if you want it to change contiunuously:
(the instant gratification method:)
Option Explicit
Private Sub TextBox1_Change()
'you'd have to restrict entry to numeric or handle error here
On Error Resume Next
Label1.Caption = TextBox1.Value / 456
If Err then
'the text wasn't numeric most likely so do something....
MsgBox "Make that Numeric Please"
End Sub
or if you wanted it to change after you'd entered something then add a
command button and:
Private Sub CommandButton1_Click()
If Err Then
End Sub
of course that assumes you have a form with a label control, a textbox
control and a command button named as above(default names)
that should give you a start
Mark
Schuyl wrote in message
news:934AB58CE5E1DAEA73C7DE0373A79AD0@in.WebX.maYIadrTaRb...
