Unanswered MDT questions
Message 1 of 14
Not sure why I keep posting MDT questions, but here goes another
one.
Why do I get errors on this after it has iterated thru a few
times. I think It might have something to do with the blank line
in the columns list but I am not sure.
Again any help appreciated. Why doesn't Autodesk ever show a
presence here?
For i = 0 To BOMstd.ColumnCount - 1
Set column = BOMstd.columns(i)
If column.Name <> "ITEM" And column.Name <> "QTY" And
column.Name <> "NAME" Then
BOMstd.RemoveColumn (i)
Next
Kent Keller
Check out the Mechanical Desktop FAQ @
http://webhome.idirect.com/~dfulford/
Replies (13)
Message 2 of 14
It would help to know exactly what kind of errors you are referring to but
one thing I can tell you right off the bat is that you are creating problems
for yourself by deleting members of a collection while in a loop. The Count
property is updated immediately whenever a member is added to or deleted
from a collection. So the moment you delete an item, your loop variable is
no longer valid AND you are accessing the wrong item from that point on. If
you delete the second item, the third takes its place, so when you access
item number 3, you really have item number 4 instead.
Try using a For Each loop instead. Or use your loop to collect the
string-based index of those columns you would like to delete and delete them
after the loop is complete, assuming they have a string-based index.
Visit me at: http://www2.stonemedia.com/franko
"Kent Keller" wrote in message
news:[email protected]...
> one.
> presence here?
> End If
> Next
> Kent Keller
Message 3 of 14
The error messages would go along with what you are explaining. I
don't remember the exact message, but it appeared it was trying to
delete a non existent column.
Ok so if I use a for each loop how do I give the index value to
remove column. It is looking for a long, not a name.
The second method are you saying to make a string of the names and
then use instr to get them back out to delete them?
What I am actually trying to do is I have a list of Names that I
want the columns to contain, and I don't want a bunch of extra
names. Ideally I would compare my list against the actual list of
column names and then delete and add as necessary. I haven't been
able to figure out a good way to go about this though.
Thanks for the help.
Kent Keller
"Frank Oquendo" wrote in message
referring to but
creating problems
loop. The Count
deleted
variable is
point on. If
you access
the
delete them
index.
Message 4 of 14
With a For Each loop, you don't specify an index at all. It works just like
the foreach statement in LISP. You will need a variable declared as the same
type contained by the collection (I have no idea what it is in this case).
For the sake of argument, let's say the data type is BOMColumn:
dim column As BOMColumn
For Each column In BOMstd.Colums
If column.Name <> "ITEM" And column.Name <> "QTY" And column.Name <>
"NAME" Then
column.Delete
Next
Fair warning: not all collections support iteration using the For Each loop.
> Kent Keller
> referring to but
> creating problems
> loop. The Count
> deleted
> variable is
> point on. If
> you access
> the
> delete them
> index.
Message 5 of 14
Frank
I had tried something similar to this, but the problem comes in
that column.delete returns "Object doesn't support property or
method"
The only way I have found to delete columns is
BOMstd.RemoveColumn (I)
With I of course being a long generated by using
For I = 0 To BOMstd.ColumnCount - 1
Kent Keller
works just like
as the same
this case).
column.Name <>
> "NAME" Then
> column.Delete
> End If
> Next
For Each loop.
Message 6 of 14
Then how about this:
For Each column In BOMstd.Columns
"NAME" Then
BOMstd.RemoveColumn column.index
Next
> Frank
> method"
> Kent Keller
> works just like
> as the same
> this case).
> column.Name <>
> > "NAME" Then
> > column.Delete
> > End If
> > Next
> For Each loop.
Message 7 of 14
Closer
It looked like it was working and then it stopped on the line
<> "NAME" Then
Saying "Method "Name" of object "IMcadColumnDefinition" failed.
I will play with it a little and see if I can figure out what went
wrong.
Kent Keller
column.Name <>
> "NAME" Then
> End If
> Next
Message 8 of 14
Frank
I found this method and it seems to work fine now.
BOMstd.columns.Remove column.Index
Why we have this method and the other beats me. It was really odd
with the other line in there. It would stop on the line shown
below one time and then if you exited and ran it again it would go
thru a few times and then stop on the line after that one.
Now I am trying to figure out how to add all the columns I want.
This crazy thing lets you add duplicates, without a error message,
but when you then manually go into the symstd you have a mess,
that you sometimes can't clean up because there are certain
columns you can't delete, but yet you have duplicates so it
complains. I was hoping to just use a on error resume next but
........ I guess not.
Everything in the Mcad stuff seems twice as hard. I sure hope
they are improving the code along with the help files for the next
go.
Kent Keller
> Closer
column.Name
> <> "NAME" Then
failed.
went
> wrong.
> Kent Keller
> column.Name <>
> > "NAME" Then
> > End If
> > Next
Message 9 of 14
So what does your final loop look like? Considering the dearth of MCAD info,
it sure would help to have a sample of working code. If you don't mind
sharing, of course.
> Frank
> go.
> Kent Keller
> > Closer
> column.Name
> > <> "NAME" Then
> failed.
> went
> > wrong.
> > Kent Keller
> > column.Name <>
> > > "NAME" Then
> > > End If
> > > Next
Message 10 of 14
Well I am ashamed to say that somewhere along the way I must have
started re writing the code under
On Error Resume Next
when it used to be above it.
If I remove that then this hangs also. I am about ready to
totally give up on writing anything with the Mcad stuff. I can
never tell if it is my Newbe - ness, or the poor documentation(so
if I keep working I will eventually end up with something that
works, or that it just plain doesn't work at all.
Frustrated......
For Each column In BOMstd.columns
Debug.Print column.Name
If column.Name <> "ITEM" And column.Name <> "DET" And
column.Name <> "QTY" And column.Name <> "SHEET" And _
column.Name <> "NAME" And column.Name <> "DESCRIPTION" And
column.Name <> "STK_SIZE" And column.Name <> "MATERIAL" And _
column.Name <> "HT" And column.Name <> "NOTES" And
column.Name <> "RELEASED" And column.Name <> "REVISED" Then
Next
Kent Keller
of MCAD info,
don't mind
> sharing, of course.
> > Frank
odd
would go
want.
message,
but
hope
next
> > go.
> > Kent Keller
> > > Closer
line
> > column.Name
> > > <> "NAME" Then
> > failed.
what
> > went
> > > wrong.
> > > Kent Keller
message
> > > column.Name <>
> > > > "NAME" Then
> > > > End If
> > > > Next
Message 11 of 14
Hi Kent & Frank,
Here it is Monday and I find two extremely over committed people working on
the weekend "Whats up with that?" ;~)
After reading your thread and thinking about your problem I started thinking
about my program for partlist standardization and thought I might ask as
well as share.
Kent, would it work to just redefine the BOM and not try to build a circle
out of a square? For my BOM/Partlist stuff I redefined what the
BOM/Partlist looked like by using a template drawing and creating my own
Symbol standard. This works great for imposing your own standard on a
part/assy. If you look through the symbol standards there is a spot in
there to redefine it and apply a custom scheme.
Kent Keller wrote in message <[email protected]>...
>Frustrated......
> End If
>Next
>Kent Keller
>of MCAD info,
>don't mind
>> sharing, of course.
>> > Frank
>odd
>would go
>want.
>message,
>but
>hope
>next
>> > go.
>> > Kent Keller
>> > > Closer
>line
>> > column.Name
>> > > <> "NAME" Then
>> > failed.
>what
>> > went
>> > > wrong.
>> > > Kent Keller
>message
>> > > column.Name <>
>> > > > "NAME" Then
>> > > > End If
>> > > > Next
Message 12 of 14
Hi Michael
Thanks for jumping in.
I try to keep learning time to evenings and weekends, and work time to the
9~5. Hence all the activity at those times.
I am not sure I follow what you are saying. I looked thru the symbol
standards and could not find a redefine method. I am not sure that would
work anyhow.
The issue came up when someone said the have some large qty of drawings with
the symstd set to ANSI and they want to add / remove columns and change
colors etc. Since ANSI in one drawing might be different from ANSI in
another, I was trying to remove all un-used un-needed columns etc. and
verify that what was wanted was either there or add it back.
If I change to a different standard, the existing partslist will need to be
deleted and recreated. We didn't want to have to do that if possible.
Kent Keller
Strobe Data Inc.
www.strobedata.com
Beta. Software undergoes beta testing shortly before it's released.
Beta is Latin for "still doesn't work."
"Michael Browne" wrote in message
> Hi Kent & Frank,
on
thinking
> well as share.
Message 13 of 14
Frank
I finally got something to work. It isn't pretty, but so far it
seems to work
startover:
For i = 0 To BOMstd.columns.Count - 1
GoTo startover:
Next
Now I am trying to figure out adding columns and I have a feeling
I am making it a lot harder than it should be. I haven't been
able to figure out where it is that is causing me to go into a
never ending loop. I think it might have something to do with
mycollection counts from 1up and the Bomstand.columns count from 0
up. As usual I am floundering, See any glaring problems with
this other than it doesn't work 8-)
Dim strColumnName As String
strColumnName = strColumnName & " " & column.Name
Next
Debug.Print strColumnName
Dim MyCollection As New Collection
Dim fOO As String
fOO = "ITEM"
MyCollection.Add fOO
fOO = "REVISED"
Dim IsThere As Variant
addagain:
For i = 1 To MyCollection.Count
ilow = i - 1
IsThere = InStr(strColumnName, MyCollection.Item(i))
Debug.Print MyCollection.Item(i)
If IsThere <> 0 Then
Set column = BOMstd.columns.Item(i)
column.COLUMNTYPE = sbUnknownType
If column.Name = "ITEM" Or column.Name = "QTY" Or column.Name
= "SHEET" Then
column.DataType = sbInteger
Else
column.DataType = sbGeneralText
Else
Set column = BOMstd.columns.Item(ilow)
= "SHEET" Then
Else
Set column = BOMstd.AddColumn(sbUnknownType, DataType,
MyCollection.Item(i), "PartNumber")
GoTo addagain:
Next
Kent Keller
of MCAD info,
don't mind
> sharing, of course.
Message 14 of 14
I switched a few things around and got it going. So far I
haven't blown anything up with it so I have my fingers crossed.
Just a couple more things to go.
The ones that I think must be busted are
IsCustomBlockUsed
and
Scale in Symbb.StandardMgr.CurrentStandard
Neither one seems to want to accept anything I try setting them
to.
Anyone been able to do anything with these?
Kent Keller
> Frank
feeling
0
