Type Mismatch when creating a selectionset
I am trying to create an empty selection set to use when exporting a dxf file. on the Set junk = line, I get the following error:
Run Time Error'13':
Type Mismatch
Here is the code.
Dim junk As AcadSelectionSet
Set junk = ThisDrawing.SelectionSets.Add("empty_set")
ThisDrawing.Export name_no_ext, "dxf", DXF
If you want to export to DXF file, you don´t need to especify the selection
set. When we export to DXF file, the selection set is ignored and the entire
drawing is
exported. In your case, you're providing a wrong selecion set.
    Dim junk As
AcadSelectionSet
    Set junk =
junk
color=#000000>
'here you
have to put the selection set created above
You have to verify if there is another selection set named "empty_set",
before you create one, because if there is a selection set with the same name,
it will cause a conflict.
face="Courier New">For i_count = 0 To ThisDrawing.SelectionSets.Count -
1
       If
ThisDrawing.SelectionSets.Item(0).Name = "empty_set" then
face="Courier New">        ThisDrawing.SelectionSets.Item(0).Delete
       End
If
    Next i_count
Yuri
I
Run Time Error'13':
Type Mismatch
Here is the code.
    Set junk =
Well, one thing that I see is
"dxf", DXF <---- should be junk
Second, what is the value in name_no_ext, it should
be a string
representing the filename.
Joe
I
Run Time Error'13':
Type Mismatch
Here is the code.
    Set junk =
Yuri, Joe,
Thanks for the help!
